Forums >> Revit Building >> Technical Support >> How can I enclose this area?
Thu, Aug 4, 2005 at 4:46:52 PM | How can I enclose this area?
cirostratus
I just need to bridge the gap between the soffit and roof/fascia. Is there a trick to it? Thanks for your help!
Fri, Aug 5, 2005 at 4:10:42 AM | RE: How can I enclose this area?
Xane
I don't think so, put in-place family
Fri, Aug 5, 2005 at 7:37:21 PM | RE: How can I enclose this area?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Just use a wall infill with an edited profile to match the gap.
Fri, May 22, 2009 at 1:04:46 PM | How can I enclose this area?
rcloonan
Hi all,
I realize this is an old post, but I am having a similar problem. The image I have attached is showing a gable in the foreground, and another gabled roof in the background. Both need to have that closed in box on the corner as I have illustrated. How do I accomplish this?  Also, what's the simplest way to add soffit and facia? Thanks for the help!
Fri, May 22, 2009 at 1:24:45 PM | How can I enclose this area?
tim123
4 Stars: 19 Votes
Do it the same way as it would be done in real life.  Create an infill panel as an in-place family, or build out the wall, as suggested in the previous posts.
Fri, May 22, 2009 at 1:31:37 PM | How can I enclose this area?
rcloonan
Ok thanks! So that is the easiest way.
What about the facia and soffit? Same thing?
Fri, May 22, 2009 at 2:12:05 PM | How can I enclose this area?
tim123
4 Stars: 19 Votes
Create the fascias and soffits using the fascia and soffit hosted sweeps, in the drop down menu under roofs in 2010 or modelling in 2009. Fill in the gap with an in-place family.
Fri, May 22, 2009 at 2:51:19 PM | How can I enclose this area?
rcloonan
Thanks a lot Tim. I had no idea that tool was there. Very easy, and very appreciated.
-Ryan
Fri, May 22, 2009 at 4:05:42 PM | How can I enclose this area?
rcloonan
Tim, after I finished putting the facia on, I noticed that it was not trimming where my roof from footprint and roof from extrusion meet. Take a look at the attached image. You can see the facia coming through the ceiling. Is there a way to clean this up?
Sat, May 23, 2009 at 3:03:31 AM | How can I enclose this area?
tim123
4 Stars: 19 Votes
I'm not sure why you have an extruded roof and a roof by footprint - seems as if it could all have been one roof.  Anyway, if you click on the fascia it has a blue dot at the end that you can stretch to the required position.  You can then add another fascia to to the other end if required.
Unenclosed Floor Area
Tue, Sep 23, 2008 at 12:45:22 PM
Calculating floor areas
Tue, Jul 21, 2009 at 3:35:52 PM
Room tags with area - area not showing up!
Thu, Aug 16, 2007 at 6:54:26 PM
Area Plan does not match Area from Materia/l Area
Tue, Feb 13, 2018 at 7:50:03 AM
Area Plans
Wed, Nov 1, 2006 at 10:03:12 AM
Page generation time: 0.1051
