Forums >> Revit Building >> Tips & Tricks >> Revit TotD – 7.5.09: Let that Bump do the Work
Wed, Aug 5, 2009 at 9:52:58 AM | Revit TotD – 7.5.09: Let that Bump do the Work
rkitect
rkitect Avatar
4 Stars: 29 Votes
How many times have you wanted the material look that Revit provides, just with a different color?  There’s a good chance that you’ve wanted this at some point before and after digging for the answer, you found that the answer isn’t quite as simple as you’d hoped.  Someone probably told you that you had to edit the image file used for render texture, then you had to find the image file and oh my goodness it got messy computer parts flying everywhere ensued… no?  Well, here’s a quick tip that should help ease the pain a little and it utilizes that little bump file that most Revit materials come with out of the box.
Changing Material Colors:
  1. With the material that you want to edit open, go to the Render Appearance tab.
  2. Check for a bump pattern being used in the material.  If the material does not have a bump file in use, this method will not work.
  3. For Color:, choose Solid color instead of Image file and select the desired color for the material.
  4. If you Update Preview, you will see that this may just wash out the pattern.
  5. Increase the amount of bump the bump image file provides to define the texture better.
  6. Update Preview again.  Repeat until the texture appears how you want it to appear.
  7. Hit OK and re-render the scene.
I like the short and sweet ones!  Means we can all go do other things! Till next time, thanks for stopping by and I hope to see you for another, Revit TotD!
As usual, you can see this tip in its full image and video glory at: http://revittotd.com/08/691
-Carl
revit_arch_09_cert_pro_rgb
Decal Bump Pattern
Tue, Oct 30, 2012 at 12:00:15 PM
Revit TotD – 2.19.10 | Dimension Formulas
Fri, Feb 19, 2010 at 10:29:46 AM
Revit TotD – 10.12.09: Revit’s “Center” Command
Mon, Oct 12, 2009 at 10:56:00 AM
Revit TotD – 7.29.09: Don’t Skip the SKP Mats
Wed, Jul 29, 2009 at 9:24:55 AM
Revit TotD – 7.9.09: Glowing Sign, Self-Illumination Based Materials
Thu, Jul 9, 2009 at 2:20:36 PM
Page generation time: 1.7497
