19 Users Online (17 Members):
Forums >> General Discussion >> Revit Project Management >> Customizing Revision Sequence Numbering
8 Posts No Rating |
Instead of the standard 1-2-3-4-etc. numbering for Revision Tags, is it possible to modify the sequencing such that it will sequence with a (#.##)?? The first # would indicate a specific GMP. The # after the dot would be the sequnce of review comments. Some examples might 5.1A, 6.2D, etc. I can modify the revision tag to show this but can the Sequence within the Revision Settings be altered. Thank you for any insight. Greg Buchanan
Why don't you just experiment with the sequesnce by giving it a beginning number. Otherwise, there are no settings that I know of.
8 Posts No Rating |
Thanks Hub, I'll see how that works
Revision Numbering |
Wed, Dec 12, 2012 at 1:11:15 PM
Revision sequence |
Tue, Sep 19, 2006 at 12:37:41 AM
Thu, Jun 18, 2015 at 2:33:41 AM
Creating Sketch Sheets and linking revision tags to Original sheet... |
Fri, Jul 14, 2017 at 11:16:31 AM
14
Revision schedule showing revision sequence numbers with empty descriptions |
Thu, Feb 28, 2013 at 3:46:03 PM
