Forums >> Community >> The Studio >> Revit to 3ds max rendering with backburner
Tue, Aug 4, 2009 at 2:55:09 PM | Revit to 3ds max rendering with backburner
davedarch
Hi, I am trying to render a scene in 3ds max using backburner. When I start the rendering I get a bunch of errors about paths and maps and materials. clearly all of my materials paths are not set up to work over a network. Firstly, I was wondering what the easiest way is to change the materials in an fbx imported revit file to 3ds max materials? Then, How would I set up the rendering paths and map locations to easily render in 3ds max with backburner?
Thanks,
-David
Tue, Aug 4, 2009 at 5:01:19 PM | Revit to 3ds max rendering with backburner
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Your Revit materials are Mental Ray materials, the are used in the promaterials library in Max, you do not need to convert them. You also need to make sure you are using the mental ray rendering engine. I honestly have not used backburner in a long time. I use distributed rendering with mental ray. This allows you to harness the power of up to 64 processors over your network to render on a single image on the host machine rather than multiple machines rendering their own small portion of the image.
3DS MAX using Backburner scan lines problems
Tue, May 28, 2013 at 5:03:25 PM
backburner on all office computer
Thu, Oct 6, 2011 at 10:28:03 AM
Revit bring into 3ds Max [ 1 2 ]
Sat, Dec 25, 2010 at 6:24:33 PM
17
Best Reference to Rendering Revit Models in 3DS Max
Mon, Oct 31, 2011 at 11:00:38 AM
Rendering in 3ds max
Thu, Apr 22, 2010 at 1:26:43 AM
Page generation time: 4.0372
