Forums >> Revit Building >> Technical Support >> Laser plotter makes raster images look "screened"
Mon, Aug 3, 2009 at 4:23:56 PM | Laser plotter makes raster images look "screened"
elduderino1234
We usually do out printing in house on an inkjet but since the set is getting so large we sent out our most recent set for printing. When we got the set back, we noticed that all of our elevations look "screened" (to use an AutoCAD term). A lot of lines that should be printing as black lines print as gray lines. Our fire rating lines (which we drew using red detail lines) are also screened. Is there any way to avoid this in the future? Is there something that we do with the PDF or plotter to fix this? Thanks
Mon, Aug 3, 2009 at 4:33:30 PM | Laser plotter makes raster images look "screened"
elduderino1234
I actually called the reprographics company and told them about the problem. They found a solution for me.
Tue, Aug 4, 2009 at 1:06:32 AM | Laser plotter makes raster images look "screened"
tim123
4 Stars: 19 Votes
Can you elaborate on that?
Wed, Aug 5, 2009 at 6:07:30 PM | Laser plotter makes raster images look "screened"
elduderino1234
They said that instead of the default printing option on their plotter, they used the "line detail" option. I'm not too sure what that means but it seems to have worked!
Imported Raster Images Not Printin
Wed, Sep 23, 2009 at 3:39:09 PM
Raster Images
Tue, Jan 19, 2010 at 9:24:57 PM
Importing Raster Images
Tue, Jun 13, 2006 at 12:55:39 PM
PRINTING SCREENED OBJECTS
Mon, Nov 2, 2009 at 1:20:32 PM
Raster Image Content Blank-2010
Fri, Aug 28, 2009 at 12:39:02 PM
Page generation time: 0.6756
