Forums >> Revit Building >> Technical Support >> Door Swings
Mon, Aug 3, 2009 at 11:00:14 AM | Door Swings
amyjolindgren
Hi everyone,
I am having issues with adding a parametric door swing on my door family.  I can't get the lines for the door to rotate at the origin of the line.  I am not sure if I am drawing the lines right, or how to dimension/attach the lines to the reference lines.  I attached my file...
~Amy
Mon, Aug 3, 2009 at 11:31:51 AM | Door Swings
amyjolindgren
...I am using Revit 2009
Mon, Aug 3, 2009 at 11:36:51 AM | Door Swings
Building families is hard to learn.  You must understand that REVIT build associations with what is already in your family.  You always want to add reference planes their dimensions (if needed) ... reference lines - their dimensions (if needed) then model elements.
With doors and windows, you have to be careful because the wall is already there and it has several elements that things will associate with.  I like to build these away from the wall on a refernce plane parallel with the wall.
In your case, try aligning your reference line with your right reference plane... not the door.
Mon, Aug 3, 2009 at 11:53:33 AM | Door Swings
amyjolindgren
I'm not sure I understand which lines you are referring to.  my issue is I can't get my symbolic line to rotate along the correct axis, if you look at my attachment and flex the lines, the point of rotation moves.  I don't want the model to change in 3D just in plan, using lines not masses.
Door swings in RCP
Thu, Jul 18, 2019 at 5:03:06 PM
creating double door with multiple swings
Fri, Oct 31, 2014 at 1:44:28 PM
Hide door swings which are visible from floor below
Wed, May 6, 2015 at 12:16:03 PM
DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011 [ 1 2 ]
Sun, Jan 13, 2013 at 11:26:10 AM
29
Door swings in 3d view
Tue, Dec 1, 2009 at 7:41:35 AM
Page generation time: 0.2859
