Forums >> Revit Building >> Technical Support >> wall sweeps up gables
Thu, Aug 4, 2005 at 8:48:15 AM | wall sweeps up gables
hip36
I am having a hard time running a freeze board profile up and down the gable ends. I tried creating a generic model but can't seam to get the profile spun around the right way, Maybe there is some trick to picking th plane in the right view? I tried offsetting a fascia but couldn't get the geometry to join to the wall sweeps. Seems like every florida house has to run the crown in the eves. Any subjestions would be greatly appreciated. Thanks, hip36
Thu, Aug 4, 2005 at 4:29:13 PM | RE: wall sweeps up gables
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Not 100% sure what a freeze board is exactly? Image may help. But doing it as a wall-hosted family may work for what you need..
Roof Gables
Sat, Nov 27, 2010 at 8:12:07 AM
Angling Wall Sweeps
Mon, Aug 15, 2011 at 1:26:41 PM
Walls with automatic wall sweeps
Fri, Aug 31, 2012 at 3:58:55 AM
Outlets and Wall Sweeps
Wed, Feb 29, 2012 at 9:39:46 AM
Intersecting Gables
Mon, May 9, 2005 at 1:49:25 AM
Page generation time: 0.5098
