Forums >> Revit Structure >> Tips & Tricks >> Door with Masonry Opening M.O.
Fri, Jul 31, 2009 at 2:17:31 PM | Door with Masonry Opening M.O.
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I have uploaded this family to the library however I thought I would post it here too.
This is a door family that has a built in M.O. masonry opening. So a 30'x84' door creates a 34" x 86" opening that can be dimension to as shown in the image below.
The door panel uses the material 'door material' and the frame uses 'frame material' so you can change it to 'metal' or whatever within the project.
Dashed Lines at outline of masonry opening above
Fri, May 29, 2009 at 5:34:43 PM
Wrapping Door Frames and Internal Door Frames [ 1 2 ]
Mon, Aug 11, 2008 at 11:02:26 AM
15
Door family - opening covers door leaf
Fri, Sep 30, 2016 at 4:36:46 AM
demolish door with out infilling opening
Fri, Jun 5, 2015 at 9:30:39 AM
Wall opening (door)
Tue, Mar 31, 2015 at 10:58:12 AM
Page generation time: 0.2077
