Forums >> Revit Systems >> Technical Support >> Custom Elbow Fitting
Fri, Jul 31, 2009 at 12:59:23 PM | Custom Elbow Fitting
SacModeler
I am trying to create a custom radius duct elbow where one end connects to a 160" x 36" duct and the other end connects to a 160" x 28" duct.  (See attached section view)
 Can anyone help me with this??
 Thanks!
 Jess
Jess JonesSacModeler
Sun, Aug 23, 2009 at 3:20:48 PM | Custom Elbow Fitting
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Use the 'sweep blend' tool to model the duct elbow instead of just 'sweep'. Profile 1 is 160 x 28 Profile 2 is 160 x 36. Use the middle center of the arc as the 'Path'. Then add your 'connectors'. You can also nest 'Profile families' to optain the option to change the two different openings via 'types'.
Looking for a GRP elbow, or thoughts on how to create one
Mon, Jan 28, 2019 at 3:13:13 PM
Duct Fitting Issue
Tue, Apr 1, 2014 at 1:16:35 PM
Plumbing Traps
Wed, Jan 30, 2008 at 10:58:23 AM
Revit Dimension Straight Leader Line with Controllable Node at Elbow
Thu, Jul 12, 2018 at 12:32:47 PM
Custom duct tee
Tue, Jul 5, 2011 at 12:50:11 PM
Page generation time: 3.5802
