17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Family Types and import/linking
17 Posts No Rating |
Is there a way when creating family types to import/link a different cad format to each family type? For example, I want to create a wall based mailbox component, I can set up parameters that will adjust the height width and what not for the different size mailboxes the manufacturer has available. In order to cut down on model sizes and complexity I would like to import a cad drawing showing the tenant and parcel boxes just as line work. (cad files from auth-florence.com) This works fine until i need to switch do a different family type and import a different cad file. Is there anyway to do this or should i just make a different file/family for each mailbox?
You can do this with y/n visibility switches but the formula of nested if's could be a pain to write. Why not do it with seperate families... build the first - save it then just continue to edit it/save as for all you different ones creating a new family fo each. If they all have the same origins... they should swap out just fine.
Family types - conditional statement |
Mon, Apr 18, 2011 at 3:59:50 PM
To Link or to group room types? Which is the best way to go? For Hotel room type |
Mon, Apr 28, 2008 at 4:42:21 PM
Purge Command - possible to purge family types accidentally? |
Tue, Aug 20, 2013 at 12:01:08 PM
Family types problem. |
Tue, Apr 21, 2009 at 10:00:20 AM
Import Question |
Thu, Nov 15, 2007 at 1:57:22 PM
