Forums >> Revit Building >> Technical Support >> Door Swing in Schedule
Thu, Jul 30, 2009 at 1:53:30 AM | Door Swing in Schedule
grgmhlch
How can we see the swing direction (left or right) in a door schedule?
Thu, Jul 30, 2009 at 7:43:45 AM | Door Swing in Schedule
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
See video turorial below.
Well it sure would be nice if we could associate the door 'flip' controls with a swing designation but I don't think you can.
You can however use a 'shared parameter' to at least tabulate the information. This is a manual text parameter and not automatic so although the information can be scheduled it needs to be manually checked for accuracy.
Here's the video tutorial below:
http://www.youtube.com/watch?v=qRozIapb7O0
Edited on: Thu, Jul 30, 2009 at 7:44:44 AM
Fri, Jul 31, 2009 at 4:30:25 AM | Door Swing in Schedule
grgmhlch
Thank you Daryl, I kind of knew this solution. Indeed is a workaround, but I imagine that some experts did already a macro or something to solve the problem automatically.
I know that there is a plugin, "revittools" which works, but is expensive.
Autodesk has a big fault in not implementing this tool which is common-sense need for architects...
I still wait for a macro, though...
I have an ideea but I don't know if it can be applied: if the trigonometrical angle of the swing could be read, than we can get the swing direction:
for an angle from 0-90 or from 180 to 270 > LH
for an angle from 90-180 or from 270 to 360 > RH
Of course the angle shall be read considering the hinge as center and the wall line as  180-0 line.
Any macro-maker? could this be a solution?
Tue, Mar 21, 2017 at 4:13:20 PM | Door Swing in Schedule
archigrafix
5 Stars: 4 Votes
XDoor does that. It places the classification in a parameter.
https://apps.autodesk.com/RVT/en/Detail/Index?id=2481590927896495348&appLang=en&os=Win64
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Tue, May 26, 2009 at 3:36:35 AM
Door Swing Question
Mon, Oct 22, 2012 at 3:51:32 PM
12
Door Schedule- 1. report host type, 2.report direction of door swing
Tue, Jan 3, 2012 at 11:37:16 AM
REVIT 2014: Door Elevations - swing lines are shown backwards? [ 1 2 ]
Tue, May 12, 2020 at 2:41:52 PM
16
Door Swing
Thu, May 18, 2006 at 4:20:39 AM
Page generation time: 0.2903
