Forums >> Revit Building >> Technical Support >> Level Consraint on a room.
Thu, Jul 30, 2009 at 12:42:44 AM | Level Consraint on a room.
LachieT
Hello Reviters,
I am just having a problem. I have created a level to refer everything too called Ground Floor 2. I also have another level called ground floor 1 which is below ground floor 2. I made the Base Constraint of all my walls ground floor 2 Then I had to seperate my plan into 2 seperate plans so I could fit them onto 2 seperate pages. Then I deleted the drawing which had both buildings on it which happend to be the ground floor 2 Floor plan. Then I noticed that my room tags were saying unenclosed for the floor area. This was because my Room tags were now sitting on Ground floor 1 level and the base constraints of the walls were above still connected to ground floor 2 level.
My question is How can I change the level the room tag sits on? It always seems to be grey'd out in the room properties.
 Thankyou for your help.
Thu, Jul 30, 2009 at 1:52:00 AM | Level Consraint on a room.
tim123
4 Stars: 19 Votes
You need to ensure that all the walls go down to the lower level.  The rooms aren't enclosed because there's a gap at the bottom of the walls.
Can't get Rooms (Room Tags) on Second Level...
Sat, Mar 21, 2009 at 3:44:40 PM
Associated level of room
Tue, Jan 2, 2007 at 6:29:59 PM
TAG ROOM SELECTING ROOM TAG IN FLOOR BELOW
Fri, May 1, 2015 at 8:24:47 AM
Room spanning multiple floors
Tue, Jun 17, 2008 at 3:13:13 PM
Adding a Numerical Level Parameter to a Room Tag
Mon, Jul 23, 2018 at 10:53:59 AM
Page generation time: 1.9570
