Forums >> Revit Building >> Tips & Tricks >> Schedule an Overhead Door
Wed, Jul 29, 2009 at 12:28:25 PM | Schedule an Overhead Door
revwriter
No matter how many ways I try to add a parameter to the overhead door family, I can't get anymore information that the size to schedule.  I'd like to be able to say it's a coiling, grille-type door in the schedule.  Suggestions?
Wed, Jul 29, 2009 at 1:16:57 PM | Schedule an Overhead Door
If you name your doors accordingly, you could use the family name ... otherwise add a parameter to the schedule that you fill in.
Wed, Jul 29, 2009 at 1:58:55 PM | Schedule an Overhead Door
revwriter
I have added a parameter but when I fill it in, it doesn't appear in the schedule.
Wed, Jul 29, 2009 at 2:35:31 PM | Schedule an Overhead Door
The easiest way of doing this.  Just add the parameter to the schedule.  This is what you have not obviously done.  You do this under the schedule properties and this does not have to be shared unless you want to export to ODBC or if you want to us it in a tag.
When you add to the family, it has to be a shared parameter if you want it in a schedule.
Wed, Jul 29, 2009 at 2:47:13 PM | Schedule an Overhead Door
revwriter
The parameter is already in the schedule.
Wed, Jul 29, 2009 at 3:15:50 PM | Schedule an Overhead Door
At 1:58 you wrote:  "I have added a parameter but when I fill it in, it doesn't appear in the schedule."
then at 2:47 you wrote: " The parameter is already in the schedule."  This doesn't make sense.  Are you filling it in in the schedule?
We are miss-communicating.  Did you read my post?
Wed, Jul 29, 2009 at 3:32:35 PM | Schedule an Overhead Door
revwriter
I know - it totally doesn't make sense.  The door schedule has door and frame type fields.  All the other doors in my project have door and frame type parameters in their properties.  My overhead door does not have door and frame type in its properties, nor can I add them such that the information (steel, wood, what have you) appear in the schedule.
Wed, Jul 29, 2009 at 4:40:43 PM | Schedule an Overhead Door
You need a better understanding of parameters.  These topics in your HELP will H E L P:
Custom Parameters
Shared Parameters
Setting up Shared Parameter Files
Adding Shared Parameters to Families
Schedules with Shared Parameters
Wed, Jul 29, 2009 at 4:46:58 PM | Schedule an Overhead Door
revwriter
I went through all those and they didn't H E L P.
Thu, Jul 30, 2009 at 4:51:54 PM | Schedule an Overhead Door
revwriter
For anyone who has been following this thread, I stumbled upon the solution:
The trick:  when you are in the door schedule and click on view properties>fields, you have the option to edit one of your chosen fields.  I chose to edit the door type field.  I clicked the open box that says, "add to all elements in selected categories" and selected doors. The overhead door now has a working door type parameter in its properties.
Overhead Door Family
Thu, Nov 1, 2007 at 8:42:53 AM
OverHead Door creation Rev 2009
Mon, Jun 27, 2011 at 9:34:37 AM
Rolling Overhead doors in Schedule
Thu, Dec 23, 2010 at 6:57:39 PM
2014 Arch: Man Access door hosted to an Overhead Door
Thu, Sep 18, 2014 at 11:08:37 AM
Cutting of Overhead Doors
Sun, Jun 16, 2013 at 11:45:18 AM
Page generation time: 1.0314
