Forums >> Revit Building >> Tips & Tricks >> Revit TotD – 7.29.09: Don’t Skip the SKP Mats
Wed, Jul 29, 2009 at 9:24:55 AM | Revit TotD – 7.29.09: Don’t Skip the SKP Mats
rkitect
rkitect Avatar
4 Stars: 29 Votes
Another simple, quick yet useful tip today!  A while back we mentioned Sketchup in our Topo tip, today I’m going to show you how to assign a material to that topo (or any object really) that you bring in to Revit from Sketchup.
Assigning Materials to Sketchup Imports:
  1. In the Material library (Manage > Materials) look for a list of “Render Material ###-###-###
  2. Select the different materials until you find one that matches the Shaded color appearance.
  3. Change the shaded color to verify you have the correct material.
  4. Once you know it is the correct material, rename the material and change any property you wish!
Overriding Line Edge Properties:
  1. Select the SKP object in the model (you may need a view other than Floor Plan to see what you want to see).
  2. Select Query in the Ribbon Options
  3. Select the object in the model to get a property dialog showing you the following information:
  4. Open the Visibility Graphics dialog (type ‘VG‘ ) and find the Layer/Subcategory that the object you queried resides on.  It will be under the Imported Objects tab.
  5. Change the line settings!
Well, hope that didn’t hurt too bad!  Note that while there are better methods to use on imports from 3DS and DWG, this method will still work for almost all imported 3D objects with materials!  Thanks again for stopping by, and I hope to see you again, for another Revit TotD!
As always, you can view this tip in its entirety at: http://revittotd.com/07/594
-Carl
revit_arch_09_cert_pro_rgb
Edited on: Wed, Jul 29, 2009 at 10:08:15 AM
Textures Folders
Tue, Feb 21, 2017 at 4:35:20 PM
Can't import SKP file!
Sun, Feb 8, 2009 at 3:58:59 PM
Revit TotD – 6.30.09: Room Tag Types “I don’t have that option!”
Tue, Jun 30, 2009 at 5:14:23 PM
SKP to RVT
Sun, Apr 22, 2012 at 6:42:04 AM
Revit TotD – 2.19.10 | Dimension Formulas
Fri, Feb 19, 2010 at 10:29:46 AM
Page generation time: 2.0737
