Forums >> Revit Building >> Technical Support >> Sharing dwg Coordinates - Revit 2010
Wed, Jul 29, 2009 at 3:28:24 AM | Sharing dwg Coordinates - Revit 2010
SoupDragon3218
I still don't understand the issue about getting a Revit model to aquire the coordinates from a dwg file with a project UCS a long way away from the WCS (350km in the one I'm working on).
Am I right to think that it won't happen automatically using the 'acquire coordinatres' function if the project is more than 1.7km away from WCS 0,0?
I can force it to work by a) rotating 'true north' to suit points on a survey dwg and then b) specifying a known coordinate taken from the dwg in autocad.
I've read elsewhere that this is going to 'corrupt' the model. Is this the case?
Is there a simpler way to do it that the old autocad boys can understand?
Wed, Jul 29, 2009 at 6:49:40 AM | Sharing dwg Coordinates - Revit 2010
There is a very good article in this issue of AUGI on REVIT's positioning system.  Read it and it will help you understand this:  AUGI|AEC EDGE
Wed, Jul 29, 2009 at 11:38:47 AM | Sharing dwg Coordinates - Revit 2010
coreed
coreed Avatar
4 Stars: 16 Votes
this may be help also
http://designreform.net/2009/07/09/revit-architecture-2010-2009-explained-coordinate-systems-side-by-side/
hth
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Exporting sheets to dwg with shared coordinates
Tue, May 6, 2008 at 9:50:37 PM
Easting Northing Coordinates all "wrong"? (2010)
Wed, Sep 15, 2010 at 2:44:37 PM
Shared Coordinates while linking Dwg into Rvt
Thu, Jun 5, 2014 at 12:06:32 PM
Revit Exports DWG Sheet to 0,0,0 not correct coordinates.
Thu, Feb 23, 2012 at 9:43:34 AM
Shared Coordinates - saving after publishing
Mon, Apr 27, 2009 at 4:45:34 PM
Page generation time: 3.3531
