Forums >> Revit Building >> Technical Support >> foundations
Tue, Jul 28, 2009 at 11:59:53 PM | foundations
CYBERCAT
1 Stars: 1 Votes
HI, I'M USING REVIT ARCHITECTURE 2010 AND WOULD LIKE TO KNOW HOW TO HAVE MY FOUNDATION PLANS DISPLAY WITHOUT DOOR OPENINGS SHOWING UP.I'M A  BEGINNER DESPERATELY IN NEED OF HELP.THANKS IN ADVANCE.
Wed, Jul 29, 2009 at 1:49:11 AM | foundations
tim123
4 Stars: 19 Votes
You can create a new plan and set the view depth to cut below the doors.  If you're talking about the doors cutting the foundations when they're right above them, you need a small piece of wall between the door and foundation.
Wed, Jul 29, 2009 at 10:10:25 AM | foundations
CYBERCAT
1 Stars: 1 Votes
hi TIM123,THANKS A MILLION I REALLY APPRECIATE THE HELP.I'LL GET STRAIGHT TO IT.HAVE A BLESSED WEEK.
Wed, Jul 29, 2009 at 10:36:37 AM | foundations
CYBERCAT
1 Stars: 1 Votes
HI TIM I TRIED THE SUGGESTIONS BUT THE WALLS ARE SHOWING UP IN MY FLOOR PLAN AND ARE ALSO OVERLAPPING THE WALLS IN FOUNDATION WHICH IS GIVING ME AN ERROR.
Wed, Jul 29, 2009 at 12:30:41 PM | foundations
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
visibility graphics; hide category (for the doors).  or right click on a door, select hide in view, and hide category... or something to that effect.
Wed, Jul 29, 2009 at 12:32:41 PM | foundations
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
scrach that... i missed the "openings" part.  alter your view depth like tim said.
Wed, Jul 29, 2009 at 2:35:36 PM | foundations
CYBERCAT
1 Stars: 1 Votes
i've tried just about every combination for the  view range(view depth i assume) but the door cuts(openings) are just not going away
Wed, Jul 29, 2009 at 2:41:54 PM | foundations
tim123
4 Stars: 19 Votes
If the doors touch the foundations you won't be able to do it.  Otherwise, place the cut plane and the top plane below the door thrreshold level.
Wed, Jul 29, 2009 at 6:16:08 PM | foundations
jarosa
jarosa Avatar
4 Stars: 5 Votes
Post a screen shot of your 3d model and a plan view? Why don't you want the door openings to show?
John
Wed, Jul 29, 2009 at 10:52:02 PM | foundations
CYBERCAT
1 Stars: 1 Votes
HI TIM123  FINALLY GOT IT.JUST ONE MORE ..HOW DO I SHOW A SPLIT LEVEL FOUNDATION?. I NOW HAVE A COPY OF MY GROUND FLOOR PLAN AND I UNDERLAYED THE MAIN FLOOR BUT THE WALLS THAT ARE SUPPOSE TO BE RESTING ON THE UPPER GROUND ARE EITHER STARTING FROM MY GROUND FLOOR OR NOT BEEN REPRESENTED PROPERLY(GREYED OUT OR DISAPPEARING WHEN I TRIED TO ADJUST THE CONSTRAINTS). I WANT MY SECTIONS TO SHOW THE FOUDATION FOOTING IN A STEP FORM WITH RESPECT TO EACH FLOOR NOT ON ONE LEVEL.
A BIG THANKS FOR YOUR HELP AND I'M NOT SITTING IDLY FOR TO BE SPOON FED, I'M READING ALMOST EVERY NIGHT FOR THE LAST TWO WEEKS AND WATCHING VIDEO CLIPS TO INCREASE MY COMPETENCE.THANKS TO ALL WHO RESPOND.GOD BLESS.
Thu, Jul 30, 2009 at 1:20:30 AM | foundations
#11
tim123
4 Stars: 19 Votes
You can use plan regions to show different parts of a plan at different levels.
Brick Corbelled Foundations
Mon, Aug 9, 2010 at 8:46:12 AM
foundations
Wed, May 14, 2008 at 1:13:53 PM
3D Views-Can you hide foundations/generic models underneath the topography?
Wed, Dec 6, 2006 at 2:04:04 PM
Revit 2024: Toposolids clash with walls/foundations...
Fri, May 31, 2024 at 6:31:39 PM
foundations reacting with columns
Thu, Oct 22, 2009 at 2:00:52 PM
Page generation time: 0.6128
