Forums >> Revit Building >> Technical Support >> Vector Printing
Tue, Jul 28, 2009 at 6:52:47 PM | Vector Printing
astew426
Hello,
 I am trying to print 30x42 sheets for a CD set, and when printed in black & white, the resolution comes out poor, grainy actually.  We print to Adobe first, and then print hard copies from .pdf form.  My coworker figured that each time we print from Revit, we print a raster image.  Is there any way to print a vector image?  Please help with any advice!
 Thanks.
Wed, Jul 29, 2009 at 1:43:20 AM | Vector Printing
tim123
4 Stars: 19 Votes
In the print setup there is an option for raster or vector printing.
Wed, Jul 29, 2009 at 11:16:00 AM | Vector Printing
astew426
Tim, and whomever else, I see that the option is presented for raster or vector printing, however, choosing vector does not produce a vector image, always.  We were trying to print the drawings with "Shading with Edges" turned out, which we found to always print as a raster.  But, when we switched it to just "Hidden Line," vector was possible.  Unfortunately we lose some of the detail that was showing in the "Shaded..." but we get clearer details in some cases, i.e. electrical fixtures show with more clarity than before, which was the goal.  If there is a happy medium out there, I would love to hear it, but for now, that will have to do.  Thanks.
Wed, Jul 29, 2009 at 12:22:14 PM | Vector Printing
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
if you're printing shaded views, your only option is raster printing.  you can however increase the resolution of your pdf.  this will be in your printer options and you should know that it will increase your output file size; quite substantially in some cases.
Wed, Jul 29, 2009 at 3:06:49 PM | Vector Printing
Manny
3.5 Stars: 6 Votes
hi,
you guys need to understand what is raster and what is vector, raster uses pixel and vector uses points.  so when you are printing shading with edges you are using pixel information when you are printing hidden your using endpoint connecting lines.
Wed, Aug 25, 2010 at 8:12:21 AM | Vector Printing
Dafpfy
3.5 Stars: 11 Votes
any news on this subject, ?
i need a vector based image from a revit plan in shade with edges.
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Wed, Aug 25, 2010 at 8:23:36 AM | Vector Printing
Sorry but as already posted, shaded can only be raster!  How else do you expect to get a tone?  You can turn of shadded and add fill patterns that are line based byt color fills are all pixel.
Wed, Jan 14, 2015 at 12:41:14 PM | Vector Printing
iamian33
iamian33 Avatar
R2015  This is an old thread but relevant to what I am experiencing.
I am finding that if there is any Transparency of model elements (even 100% transparency) then Revit forces to Raster printing.  I wish this wasn't so ... Has anyone found a work-around?
Ian Shafer
Principal Consultant
True North S&F Consultants
Vector Printing - Ceilings Disappear
Wed, May 28, 2014 at 9:12:41 AM
Losing wall tags when printing.
Fri, Jan 20, 2017 at 9:07:39 AM
Revit 2018 - Coordination Models and Printing to Vector
Fri, Apr 21, 2017 at 2:49:50 PM
Printing vector changes solid to hidden line, shaded areas don't show correctly
Mon, Apr 20, 2015 at 10:56:21 AM
Vector printing and rasterized transparency
Thu, Jul 25, 2013 at 4:59:33 AM
Page generation time: 0.9426
