Forums >> Revit Building >> Technical Support >> Wall Split
Tue, Jul 28, 2009 at 11:09:58 AM | Wall Split
AMSTER
Hi,  I have a single wall with two columns  making three equal parts. I split the wall in order to apply a diffrent wall material between the columns. When I split the wall the elevtions work but when I view the plan I get a line where the split is located. Anyone know how to get rid of the line in plan? Thanks
Tue, Jul 28, 2009 at 11:26:08 AM | Wall Split
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
when all else fails: line work tool - invisible lines
Revit 2010 - It's a good thing... Stop Fighting it.
Tue, Jul 28, 2009 at 11:52:14 AM | Wall Split
There is a line because you told REVIT they are different walls.  If you just wanted a different finish rather than material, you could have split the wall face and "poured" on a different finish.  Then the split would not show in plan.
Tue, Jul 28, 2009 at 11:52:44 AM | Wall Split
tim123
4 Stars: 19 Votes
If you use the split face tool in elevation it won't affect the plan and then you can apply the material in elevation.
join wall with split region with wall without split region
Wed, Dec 21, 2011 at 8:30:01 AM
Split Region Wall Foundation Issues
Wed, Jun 1, 2011 at 5:36:25 PM
Wall Split
Tue, Apr 19, 2005 at 2:21:49 AM
Split Facing and Painting both sides of a wall?
Fri, Jan 13, 2017 at 10:52:50 PM
Split face for multi colored wall
Wed, Oct 7, 2020 at 3:18:11 PM
Page generation time: 2.2672
