Forums >> Revit Building >> Technical Support >> Materials for in-place families
Tue, Jul 28, 2009 at 2:02:41 AM | Materials for in-place families
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
i have multiple in-place families created as different catagories..
how do i create a render material finish for them?
Tue, Jul 28, 2009 at 7:01:49 AM | Materials for in-place families
You can assign them individually to each when you create the form, just like you can when you build an independent family.  Read this topic in your HELP Applying Materials to Elements
Tue, Jul 28, 2009 at 2:58:02 PM | Materials for in-place families
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
thanks Hub- can you please explain this help to me?
i selected the in-place family that i want to assign a material to..
in the first screenshot you see i selected the in-place family parapet..
Tue, Jul 28, 2009 at 3:07:37 PM | Materials for in-place families
You assign the material properties when you build the element.  Extrusion / sweep / revolve ....properties.  Not after the family is built.
Tue, Jul 28, 2009 at 7:39:37 PM | Materials for in-place families
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
Hub- that could be- but that's hard to believe..
how would you know what the final render material will be
for an in-place family element?
somebody please step in here and help us out..
Wed, Jul 29, 2009 at 3:28:21 AM | Materials for in-place families
4 Stars: 205 Votes
"Hub- that could be- but that's hard to believe..how would you know what the final render material will be for an in-place family element?" - WYS, you render the object, if you don't like pick in the object go to the properties and you have a parameter "Material", Change that for the material you want, also, go to Settings>Materials and you can change that there....
Wed, Jul 29, 2009 at 3:54:52 AM | Materials for in-place families
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
i don't find no parameter material..
Wed, Jul 29, 2009 at 4:47:26 AM | Materials for in-place families
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
it's a bunch of tricky stuff you have to do in the
family types dialog- i been through this before
but i forget everything..
i tried dealing with it but i couldn't..
and you know everybody would rather play cat and
mouse than write out the steps.. yeah..
1. click on the in-place family you want to change
materials for.
2. ?
3. ?
4. ?
5. ?
6. ?
thank you so much..
Wed, Jul 29, 2009 at 7:37:20 AM | Materials for in-place families
tim123
4 Stars: 19 Votes
 WWHubs method.
Go into edit mode of the family.
Assign materials to the individual components.  If they are likely to change create a material specifically for that item, such as 'Gadget 2 finish' in the materials editor and assign that material to the component.
Close the family.
Alternatively, as Typhoon suggested, edit the family and give the material a parameter, such as Gadget finish, close the family and then there will be a material parameter in the family properties,
Wed, Jul 29, 2009 at 6:38:15 PM | Materials for in-place families
jarosa
jarosa Avatar
4 Stars: 5 Votes
What is not obvious to the beginner user (like me before I figured this out) is that you can only change the properties of an inplace family is in the individual extrusions, sweeps, etc. If you think about it, a family can have more than one extrusion and you may want to apply a different material to the different elements of the family, thus you must apply properties to each element of the family.
Sooooo.
You would select the family >
edit in place >
select the element (extrusion, sweep, etc.) >
edit properties - the dialog box appears and you can select/edit the materials.
If you're using 2010 the ribbon shows the edit and property icons in different locations from context tab to the next...and that's a gripe for another thread.
Wed, Jul 29, 2009 at 7:07:59 PM | Materials for in-place families
#11
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
way to go connecticut- thanks much..
Filter for in-place families
Tue, Jan 22, 2013 at 8:49:24 AM
Setting the materials for symbol families
Thu, Jan 20, 2005 at 11:09:39 PM
In place families above the view range are still appearing
Tue, Dec 23, 2014 at 9:17:05 AM
Massing Vs. In-Place Families
Fri, Jul 17, 2009 at 7:23:22 AM
Materials in families- weird behavior
Fri, Apr 9, 2010 at 7:14:52 AM
Page generation time: 0.8889
