12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> materials keep going missing
2 Posts No Rating |
Hi, I'm using revit 2010 and use 3rd party materials in my building. I've assigned materials to different elements and all seems to be working well, except that revit doesn't seem to be able to remember more than 1 path to an 'external' material image file. For instance, if I add concrete to my walls, I loose the wood on the door and vice versa. Anyone ran into this problem before?
i have the same issue trying to use materials that are not in the presets folder for Revit. Under Options/Rendering I add the path to the texture map I am using. The problem is I have to do this everytime I open the project
2 Posts No Rating |
odd stuff Alabaster: added external material to the floor in addition to the walls and those two seemed fine, whereas the external material on the door and wall don't seem to like each other ... if anyone has a clue ... will keep toying around with it until frustrated :-(
I'm not sure yet but after playing with it a bit it seems that if you load the images into the default Revit location (C:\Program Files\Autodesk Revit Architecture 2010\Data\Rendering\assetlibrary_base.fbm\Materials\Generic\Presets) you can get the materials to stick. Good luck!
Missing materials |
Wed, Jul 14, 2004 at 10:57:17 AM
Missing Materials |
Wed, Jun 19, 2013 at 2:22:26 PM
Purged unused and now all of my materials are missing |
Mon, Oct 28, 2013 at 11:43:17 AM
My jpeg materials keep missing |
Thu, May 13, 2010 at 7:54:23 AM
Missing Materials |
Mon, Oct 27, 2008 at 7:25:38 AM
