Forums >> Revit Structure >> Technical Support >> Properly showing slab edge in section.
Mon, Jul 27, 2009 at 1:51:15 PM | Properly showing slab edge in section.
jmorabito
I am trying to get my slab edges to show up properly in details.  If you look at the picture you can see the blue line of the regular slab extends all the way to the masonry foundation wall.  How can I make this line end where the edge slopes?  I have tried joining geometry but that doesn't seem to be allowed.  Thanks.
I am working in Revit Struct. 2010, btw.
Mon, Jul 27, 2009 at 2:54:00 PM | Properly showing slab edge in section.
For most details like this, I just use edit cut profile.  If you have not learned to use this yet, please read your HELP on the subject.
Tue, Jul 28, 2009 at 8:24:05 AM | Properly showing slab edge in section.
coreed
coreed Avatar
4 Stars: 16 Votes
FYI, Edit Cut Profile is view specific and does not modify the geometry of the entire slab. But as WWHub, it is used for these type of conditions when detailing section cuts.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Jul 28, 2009 at 8:34:58 AM | Properly showing slab edge in section.
jmorabito
got it looking correct.  thanks.
Mon, May 3, 2010 at 5:27:10 PM | Properly showing slab edge in section.
mcantwell
mcantwell Avatar
See if making the materials the same helps.
Edited on: Mon, May 3, 2010 at 5:31:36 PM
Thickened Slab not joint properly
Wed, Dec 11, 2013 at 7:18:45 AM
Floor slab edge not joining right REV2008
Tue, Aug 14, 2007 at 3:37:07 AM
Creating slab edge...
Tue, Nov 4, 2008 at 3:36:02 PM
"Could not create Slab Edge"
Tue, Feb 17, 2009 at 1:40:42 PM
RC upstand on the edge of an RC slab
Thu, Jul 14, 2011 at 11:04:56 AM
Page generation time: 1.0263
