Forums >> Revit Systems >> Technical Support >> Light switches not showing on floor plan
Mon, Jul 27, 2009 at 10:19:43 AM | Light switches not showing on floor plan
patrickj75
Revit MEP 2010. I placed light switches on my floor plan and now I can see them. They show up on my sections though. I've changed the cut plane and viewing range but nothing seems to work. I'm only having this issue on my first floor plan.
Mon, Jul 27, 2009 at 10:25:03 AM | Light switches not showing on floor plan
4 Stars: 205 Votes
I don't work with MEP and i can't see images of what are you seeing but did you check in that "first floor plan" if you have the view in "Coarse/Medium or Fine mode"??? or in VG if you turned OFF that Category?
Mon, Jul 27, 2009 at 10:32:44 AM | Light switches not showing on floor plan
patrickj75
That level is on. Changing it from coarse to fine didn't do anything.
Fri, Apr 29, 2011 at 1:25:26 PM | Light switches not showing on floor plan
tzd0004
try adjusting the elevation of the device in the properties before you place it..
hope this works!!
Fri, Apr 29, 2011 at 1:50:45 PM | Light switches not showing on floor plan
coreed
coreed Avatar
4 Stars: 16 Votes
by default light switches are above the cut plane. you will have to raise the cut plane to see the light switches
Edited on: Fri, Apr 29, 2011 at 1:51:10 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Apr 29, 2011 at 2:02:01 PM | Light switches not showing on floor plan
tzd0004
even you try to change the cut plane it might not work..the default elevation of the device was 13' in my computer so I had to adjust the elevation to reasonable height..
Thanks..
Fri, Apr 29, 2011 at 2:05:00 PM | tzd0004
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting tzd0004 from 2011-04-29 14:02:01
Thanks..
who would put a light switch at 13'. you might want to fix that family.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Apr 29, 2011 at 2:14:19 PM | Light switches not showing on floor plan
tzd0004
Have no clue but it was default on my PC.. just tought patrickj75 might have the same problem since he has already tried to change the cut plane settings..
peace!!
Floor plan showing ceiling fixtures and wiring to switches
Wed, Feb 18, 2009 at 2:49:44 AM
light wiring in architectural floor plan
Mon, Mar 6, 2017 at 9:26:58 AM
Reflected Ceiling Plans not showing in Electrical Plans
Wed, May 4, 2011 at 1:19:05 PM
Simple Light with Multiple Switches
Thu, Jul 19, 2018 at 7:34:17 AM
Light switches
Mon, Sep 22, 2014 at 1:04:57 PM
Page generation time: 3.0516
