Forums >> Revit Building >> Technical Support >> Setting up "office standard families"
Mon, Jul 27, 2009 at 8:41:12 AM | Setting up "office standard families"
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
I work for a large Commerical Frim in No. Little Rock, AR. We are in the process of switching the last of the CAD guys over to REVIT. This is turning out to be a big challenge for some of them. Me and the other BIM manager have set up all our office templates and standards. But now we are to the point of making some "office standard" families.
 I have been put in charge of this task, and i know it is somethign that will not happen over night. I am wanting to know how other offices have been handling this task. i would like to create some advanced families. For the less experienced guys so that if they wanted to do a typical millwork section it would note it and dimension it all for them. i understand how all the parameters and everything works inside the families, but i think my main question is how much is to much? Should i worry about bogging these families down with to much info and options? I am hopping to try and make it easy as i can so if one guy wanted to add a view panel to his door, he could just trun on the view panel parameter and it be there noted and placed in out office stadard. and ideas, suggestions, past experinces, or links to information on this topic would be helpful. reply on here or email me if you need to (ball@taggarch.com)
Allen Ball
J. Allen Ball
Mon, Jul 27, 2009 at 9:38:20 AM | Setting up "office standard families"
We are an office of 40+.  We currently have 3 people who are good family builders and we will be training a few others this week.  We are going to train these other builders on how to make simple 2D families and annotative families.  We really do not want them dealing with parametric or complicated 3D families but we know that in order to be productive, we need a few other family builders.  We also don't want users building 3D familieswhere 2D is all that is required.
Office standards are hard to establish and maintain but we are working on that.  This is one reason why we are having this training.  We want our users to make good decesions following some simple guidlines.  We will not give them write access to the library.  That will be restricted to a few that will review families and approve or modify them before they go into the library.
Our biggest concerns at this time are naming conventions for families, sub-categories, parameters, materials, reference plane.
For major items likes doors, we believe you don't want one family does all.  Building a family like that is too complicated for most users to build or modify so we have a few major families.  As an example, for HM doors, we have solid panel doors, doors with lites, doors with sidelite then solid double doors, double doors with lites.
All of these doors have been built to our standards and have our parameters in so they will schedule correctly. If a project demands something special, we will insist that the project team uses something close and gives it a new type name so that one of our top builders can modify a family and it can be sustituted.
We also name all approved families with our office initials at the beginning so that they are easily identified.
Mon, Jul 27, 2009 at 12:25:06 PM | Setting up "office standard families"
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Thanks for the tip Hub,
J. Allen Ball
Tue, Jul 28, 2009 at 7:48:36 PM | Setting up "office standard families"
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
hey hub, is there a way i can put dimensions in a family section, and have them show up in the model when i draw a section threw the family?
J. Allen Ball
Wed, Jul 29, 2009 at 6:46:07 AM | Setting up "office standard families"
Not that I know of.
I really don't like family hosted details.  I think they take up too much space and are hard to work with.  In detail views, I would rather turn off the model element, like a window, and add the detail component.
Tue, Aug 11, 2009 at 2:42:42 PM | Setting up "office standard families"
MARS1276
1 Stars: 1 Votes
I will agree with WWHub.  I was in charge of creating a lot of families for our own CAD-to-Revit conversion.  At first I started making our typical doors.  I tried to create a nested family of doors to show different panels within each frame.  I got this idea from a training tip online.  What I found out was that I had wasted a WHOLE bunch of time trying to get each panel to work, parameters for each panel to show the correct material, and then I don't recall being able to schedule them all.
I would suggest keeping it simple.  If you want, create a detail component that you can place in a section of a window or door that will show all of the detail (with notations), or better yet, just do what we do; create a sheet just for window and door details.  Sometimes of course you may not need an entire sheet, but to elaborate, you could create a project with nothing but window and door details drawn as drafting views.  Then when you are in a project, you could import each view for what you need individually.
 I have found in the past that WWHub has some great advice.
Tue, Aug 11, 2009 at 5:04:13 PM | Setting up "office standard families"
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
i agree, Hub is one of the best
J. Allen Ball
Line weights reverting to standard
Thu, Jan 6, 2011 at 7:10:38 AM
How do you change a "generic model" family into a "mechanical equipment" family?
Fri, Apr 6, 2018 at 6:18:19 PM
"ADA Clearances" in families
Tue, Sep 11, 2012 at 10:34:16 AM
How to make a "Model in-place" a "Family"
Thu, Mar 17, 2011 at 5:07:59 PM
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
Page generation time: 0.7663
