Forums >> Revit Building >> Technical Support >> Need help dimensioning this wall!
Sat, Jul 25, 2009 at 11:14:13 AM | Need help dimensioning this wall! 2010 revit
rwswartz
I am having trouble dimensioning this wall I have tried the aligned and linear but it will not do it.  The linear will but I want the text to be aligned.  Is there a trick to do walls that are at an angle? I attached a pic of the wall. I am using 2010
Edited on: Sat, Jul 25, 2009 at 11:16:35 AM
Sat, Jul 25, 2009 at 11:39:57 AM | Need help dimensioning this wall!
tim123
4 Stars: 19 Votes
Hold your mouse over the point and hit Tab a few times - you probably have to cycle right through (4 or 5 times) till the dot on the corner highlights.
Sat, Jul 25, 2009 at 12:40:52 PM | Need help dimensioning this wall!
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Yes use the 'tab' key to cycle thru potential dimension references. See image below.
Sat, Jul 25, 2009 at 10:56:26 PM | Need help dimensioning this wall!
rwswartz
Thanks I will try that
Revit 2008 - Dimensioning Curtain Wall
Tue, Feb 19, 2008 at 5:26:46 PM
Wall dimensioning
Thu, Jan 19, 2006 at 5:28:48 PM
Dimensioning to the centerpoint of an arc
Tue, Jul 29, 2008 at 4:11:55 PM
Revit 2010-Dimensioning
Wed, Jan 20, 2010 at 10:47:16 AM
Dimensioning Angular Walls
Mon, Jan 16, 2006 at 6:34:07 PM
Page generation time: 4.3985
