Forums >> Revit Building >> Technical Support >> Openings on a curved roof
Fri, Jul 24, 2009 at 4:08:45 PM | Openings on a curved roof
hoblo70
I have created a curved roof by creating a mass that has a toroid void taken out of it.  This leaves me with the desired curve.  I have also cut out openings for skylights along the radius of the curve so my opening is perpendicular to the curved surface.
When I go and create a roof it simply extrudes the surface staright up so the edges of my openings are perpendicular to the floor surface instead of being at an angle and perpendicular to the radial of the curved roof.
How can I get my edges to follow what my mass openings are?  I want my model to look like it would be if it was actually built not like a staight vertical shaft cutting through a curved surface.
Sat, Jul 25, 2009 at 2:35:49 AM | Openings on a curved roof
tim123
4 Stars: 19 Votes
It may be better to leave the voids out of the mass before creating the roof.  Once the roof is formed, create the voids (in the roof category) and cut them out of your roof.
Curved wall openings
Fri, Oct 15, 2010 at 12:42:11 AM
Dome roof openings
Tue, Aug 16, 2005 at 3:37:24 AM
roof slopes with skylight openings and notch
Wed, Apr 21, 2010 at 1:09:29 PM
11
CURVED MASSING FOR ROOF BY FACE
Tue, Jul 20, 2010 at 5:24:24 AM
Curved Walls with Openings
Tue, Feb 26, 2013 at 12:35:38 PM
Page generation time: 0.7419
