Forums >> Revit Building >> Technical Support >> Temporary Dimensions and Wall centerlines
Fri, Jul 24, 2009 at 1:42:24 PM | Temporary Dimensions and Wall centerlines
wohlfie
I am quire new to Revit, but am having a major problem with temporary dimensions.
Despite the fact that i have set the option to "Faces", it still does temporary dimensions to centerlines.
To make things worse, often the 'move witness line" grip doesn't show and usually when it does it does not move off the center.
Any thoughts? Temporary dimensions are practically worthless to me unless i can get them to come from the face of the wall.
Thanks.
Fri, Jul 24, 2009 at 1:53:10 PM | Temporary Dimensions and Wall centerlines
4 Stars: 205 Votes
In Settings>Temporary Dimension Properties, you can change...
Fri, Jul 24, 2009 at 2:16:33 PM | Temporary Dimensions and Wall centerlines
wohlfie
Typhoon-
 As I said, I have set it to faces. That appears to have no effect whatsover.....
Fri, Jul 24, 2009 at 2:33:11 PM | Temporary Dimensions and Wall centerlines
Strange - works for me.  Are you sure you are setting temporary dimension - not dimension.
In addition, you can always click on the temporary blue gip and it will cycle through the location options available.  This works on any of the blue grips.
Fri, Jul 24, 2009 at 2:43:53 PM | Temporary Dimensions and Wall centerlines
4 Stars: 205 Votes
Put a screenshot of that here please!!
Mon, Aug 3, 2009 at 3:12:16 PM | Typhoon
wohlfie
Quoting Typhoon from 2009-07-24 14:43:53
Sorry i did not get back to this for so long. Attached are two screenshots. One shows the temporary dimension settings set to faces. The other is an example.
I started a brand new file from the stock template for this example. Set the Temp Dimensions.
Drew one "Generic 8 wall" then a wing wall.
Note that when selected, the temp dimension of the wing wall is to the CENTERLINE of the base wall. In addition, THERE ARE NO witness line adjustment options for the dimension at the length of the wing wall.
Any ideas?
Mon, Aug 3, 2009 at 3:18:18 PM | Temporary Dimensions and Wall centerlines
I see from the black screen that you are a CAD user so your colors are different.
Is the 4' dimension temporary?  It appears to be... click on the orange dot at the center of the wall - that would be blue if you had kept the white screen.
Mon, Aug 3, 2009 at 3:48:03 PM | WWHub
wohlfie
Quoting WWHub from 2009-08-03 15:18:18
I found the white background a little hard on the eyes, but yes, it is a temporary dimension. I can drag the wall end as you suggest and it snaps to the wall face, but then Revit seems to do its join and it goes back to the centerline!!!
Tue, Oct 11, 2011 at 10:58:37 PM | Temporary Dimensions and Wall centerlines
idraw38
Try going to manage tab, select additional settings, select temporary dim, select faces of core., OK. If you click the blue tabs, it should cycle to the core faces.
Carl
Thu, Oct 20, 2011 at 1:31:20 PM | Temporary Dimensions and Wall centerlines
GrahamRyan
does anyone else get their temporary dimensions always defaulting to something off screen? if im zoomed in on a plan, and selecting items, it alway picks a reference out of my view screen, and if I move to include that reference in my view, it picks something else off my screen again to draw its temporary dimension from..
Wed, Jul 1, 2009 at 10:50:50 AM
temporary dimensions disappeared
Wed, Apr 25, 2012 at 10:37:51 AM
Temporary dimensions and stacked walls
Wed, Feb 9, 2011 at 8:47:10 AM
temporary dimension properties must be broken.
Sat, May 20, 2006 at 2:58:18 PM
Mon, Jun 30, 2014 at 9:57:47 AM
Page generation time: 0.6178
