Forums >> Revit Building >> Technical Support >> 2010 Crashing every time I try to import a family.
Fri, Jul 24, 2009 at 1:12:27 PM | 2010 Crashing every time I try to import a family.
Xaquin
it started out in one project.  I'd try to import a family (window, furniture, etc.) and as soon as I'd click on the file, Revit would crash.
Now it happens in every project.  Can anyone advise me?  I have stuff to get done on a deadline and don't have time to completely redo it in 2009
Fri, Jul 24, 2009 at 1:17:07 PM | 2010 Crashing every time I try to import a family.
Xaquin
oh yeah, running Windows XP professional (SP3) with all drivers updated (graphics card, mobo, etc.)
Pent 4 at 3.2 ghz.
2 gigs of RAM
NVIDIA Quadro FX 3400/4400
never had a single problem with either Revit 2008 or 2009
Fri, Jul 24, 2009 at 1:44:30 PM | 2010 Crashing every time I try to import a family.
4 Stars: 205 Votes
Yeah, there are several threads about this issues, see this: http://www.revitcity.com/forums.php?action=viewthread&thread_id=16027&start=15
See the System Requirements from Autodesk: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=12431819
Fri, Jul 24, 2009 at 1:53:50 PM | 2010 Crashing every time I try to import a family.
Xaquin
I have tried options presented in that thread (even posted in it myself hehe) and am above the requirements needed for the program.  Still crashes every time I try to import a family.
Fri, Jul 24, 2009 at 2:28:04 PM | 2010 Crashing every time I try to import a family.
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Xaquin,
Can you post your journal file from your latest crash? I will take a quick look for ya.
Fri, Jul 24, 2009 at 2:34:04 PM | 2010 Crashing every time I try to import a family.
Xaquin
I hate to say it, but I don't know what that is hehe
once I find out though, it's really easy to replicate a crash
Fri, Jul 24, 2009 at 2:37:11 PM | 2010 Crashing every time I try to import a family.
alabaster2513
3.5 Stars: 25 Votes
if you go to Program Files/Autodesk Revit Architecture 2010/Journals it will be a .txt file with the latest time on it
Fri, Jul 24, 2009 at 2:38:36 PM | 2010 Crashing every time I try to import a family.
Xaquin
ah ha!
found it =)
here is the last page of it (there are several more before it, and if you want, I can post them here too)
'E 24-Jul-2009 14:19:14.182;   0:< Jrn.PushButton "ToolBar , {}{} , Dialog_Family_ManyInstDbar" _         , "Load..., Control_Family_FamilyLoad"  ' 0:< DBG_WARN: Could not create a bitmap. Probably memory is low. Trying to free triangles memory.: line 79 of .\PreviewUtil.cpp.   ' 0:< DBG_WARN: Could not create a bitmap. Probably memory is low.: line 88 of .\PreviewUtil.cpp.   ' 0:< Exception occurred   ' 0:< ExceptionCode=0xc0000005 ExceptionFlags=0x00000000 ExceptionAddress=7CA3ECBD   ' 0:<   System (KB) [Available /  Total ]  [Revit Memory Usage (KB) ---------------- ]   ' 0:< RAM Statistics:   577776 /  2095188    464832=InUse   466672=Peak  1052580=DeltaForRevit   ' 0:< VM  Statistics:  1285820 /  2097024    408640=InUse   416092=Peak   402564=DeltaForRevit     ' 0:< funcUnhandledExceptionFilter is executed in a non-main thread (id = 3036, tag = AFileNavDialogBase::DoModal).   ' 0:< VM Delta: Available -13 MB -> 1257 MB, Used +9 MB -> 401 MB   ' 0:< Got a message. Go to the crash protection!   ' 0:<   System (KB) [Available /  Total ]  [Revit Memory Usage (KB) ---------------- ]   ' 0:< RAM Statistics:   577964 /  2095188    475420=InUse   485536=Peak  1041804=DeltaForRevit   ' 0:< VM  Statistics:  1288688 /  2097024    410616=InUse   420640=Peak   397720=DeltaForRevit     ' 0:< 1DE63AE0 CompactMemoryManager Memory Statistics: 131072 KB with 4096 KB view   ' 0:< num open transaction groups is 0   ' 0:< num open transaction groups is 0   ' 0:< MessageBox "An unrecoverable error has occurred.  The program will now be terminated.  All of your data has been recently saved, so there is no need to create recovery files."   '             1:--API application event DialogBoxShowing returned status DidNotRaise   'H 24-Jul-2009 14:20:18.839;   0:<   Jrn.Data "MessageBox"  _          , "IDOK", "An unrecoverable error has occurred.  The program will now be terminated.  All of your data has been recently saved, so there is no need to create recovery files."  'C 24-Jul-2009 14:20:18.855;   0:< program terminated
Fri, Jul 24, 2009 at 2:50:29 PM | 2010 Crashing every time I try to import a family.
alabaster2513
3.5 Stars: 25 Votes
increasing your virtual RAM may help the problem, but I recommend getting more physical RAM. You don't have enough thats for sure.
Fri, Jul 24, 2009 at 2:53:30 PM | 2010 Crashing every time I try to import a family.
Xaquin
yeah =/
I oughta know by now that 'reccommended' is computerese for 'required'
Revit 2010 keeps crashing
Wed, Jul 15, 2009 at 12:17:15 PM
Windows Explorer Crashing almost everytime I look at or move an, .rfa file
Thu, Mar 17, 2011 at 4:16:45 PM
Help! Revit Crashing when I...
Tue, Aug 25, 2009 at 1:05:10 PM
Having trouble import Autocad files into Revit 2010
Tue, Jun 9, 2009 at 8:55:02 AM
Revit 2010 Dwg. Import problem
Thu, Sep 2, 2010 at 1:52:03 AM
Page generation time: 0.9091
