Forums >> Revit Building >> Technical Support >> extrude taper ellipse.
Thu, Jul 23, 2009 at 3:40:34 PM | extrude taper ellipse.
Warchitect
4 Stars: 5 Votes
How do you extrude an ellipse to look like this toilet in the link below. I just want a basic solid mass to place in my project.
thanks michael.
http://www.us.kohler.com/onlinecatalog/detail.jsp?from=thumb&frm=&module=Toilets&item=9676302&prod_num=3492&section=2&category=13
Thu, Jul 23, 2009 at 3:56:13 PM | extrude taper ellipse.
wheelergc
Try solid blend you just have to set the top and bottom and it is done.
I don't want to be interesting. I want to be good.
Thu, Jul 23, 2009 at 4:58:19 PM | extrude taper ellipse.
Warchitect
4 Stars: 5 Votes
Great thanks a lot.
One more noob question. I applied "material" to it so i could apply different colors etc..but i use the family in the drawing, and although the material parameter can be changed, it doesnt seem to be anything but grey solid in my model space. if i set it to glass say, its still grey opaque. any suggestions?
 I know its highlighted red, but check the screen shot for the screen im looking at.
Michael
Thu, Jul 23, 2009 at 5:37:14 PM | extrude taper ellipse.
wheelergc
Go in and edit your material on the first screen there is a box showing the color.  There is a check box for use render color for shaded view or something along those lines. That should work for you.
Thu, Jul 23, 2009 at 7:38:54 PM | extrude taper ellipse.
Warchitect
4 Stars: 5 Votes
So it doesnt work...:-( I saw the box to change the materials but still grey.
 here is the family file. please help me assign a meterial to it. also let me know what I did wrong.
Its always grey in the regular shaded views. and does not appear like anything other than default grey when rendered, no matter what material i apply. either when the "use render appereance" is on or off. tried this in both the family editor and the plan im using the item it...
Thu, Jul 23, 2009 at 9:54:27 PM | extrude taper ellipse.
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi Warchitect....to assign a new material, in your project go to Settings--> Materials...Toilet color (is the material I created), and change it to whatever material you want....
Thu, Jul 23, 2009 at 10:54:45 PM | extrude taper ellipse.
Warchitect
4 Stars: 5 Votes
thanks, a i figured it out, when you import the part into a proj. the material of the item has to be set "by catergory" so with your advice and some more looking i figured it. thanks all.
problem with ellipse
Fri, Apr 13, 2007 at 10:29:32 PM
Dimensioning an Ellipse?
Thu, Apr 24, 2008 at 12:16:07 PM
Double ellipse mass
Wed, Nov 5, 2008 at 1:59:06 AM
Glazing wall with ellipse form
Tue, Feb 28, 2006 at 4:44:41 AM
extruding solids using angle of tapering
Thu, Apr 13, 2006 at 1:04:45 AM
Page generation time: 0.0268
