Forums >> Revit Structure >> Technical Support >> TOPO SURFACES RETAINING WALL HELP
Thu, Jul 23, 2009 at 10:37:26 AM | TOPO SURFACES RETAINING WALL HELP
DWDRAFT1
I have built 3D topo contours inside of autocad and have placed them into my revit model.  I have checked and double checked making sure all the contours are closed.  My problem is that the contours are not reacting around the retaining walls like they should.  As you can see in the attached.  The near side  (low grade) should be even all the way around the bottom of the wall.  The far side (high grade) is about the same but tapers down to low grade out at the ends.  As you can see the grade is trying to connect from high to low in a gradual slope.  It is not even following the 'z' coordinate lines that I have in the model at these points.  Any help in resolving this would be greatly appreciated.
Thu, Jul 23, 2009 at 10:49:52 AM | TOPO SURFACES RETAINING WALL HELP
Edit your topo in Revit, not CAD and add elevation points along your wall on each side of the wall.
Mon, Aug 3, 2009 at 11:53:02 AM | TOPO SURFACES RETAINING WALL HELP
Rooster13
ask that revit genius sitting beside you........
Creating curved retaining wall that aligns to topography...
Thu, Dec 22, 2011 at 12:30:03 PM
Surface pattern to Topo surface
Mon, Aug 19, 2013 at 10:50:10 PM
Revit 2013 - Sloping site & retaining walls
Fri, Apr 19, 2013 at 2:55:40 PM
Revit Architecture 09- Topography and Retaining Wall
Mon, Oct 12, 2009 at 4:15:33 PM
Rendered materials on topo surfaces
Thu, Jun 15, 2006 at 8:46:47 AM
Page generation time: 0.5410
