Forums >> General Discussion >> Revit Project Management >> Objects not rendering transparent
Thu, Jul 23, 2009 at 10:28:58 AM | Objects not rendering transparent
897PPK798
Hello,
I am making a model of a 3D diagram with varying shapes made from masses. Certain shapes are to be rendered opaque with flat colors and others as transparent objects with color (please refer to Sketch Up image below for clarity). I am using Revit Architecture 2009 and so far my attempts to render the transparent masses have failed. Allow me to explain:
-I make a mass, go to its properties before "Finish Mass" and apply to it a material (ex: A default material with a particular color)
-Within its Rendered Appearance Tab, under Transparency I set the transparency to 1 = 100%
-When rendered through the basic Revit Rendering Plugin - that object appears opaque with the flat color.
Is there a way to render objects in Revit that are transparent similar to the Sketch Up image posted below?
 Below please find images of my process in Revit to understand my question.
Thu, Jul 23, 2009 at 10:38:17 AM | Objects not rendering transparent
897PPK798
Images that I mentioned above.
MAKING DEMOLISHED OBJECTS TRANSPARENT
Tue, Mar 12, 2013 at 2:02:34 PM
Transparent furniture items
Mon, Jul 11, 2011 at 8:54:28 PM
Windows are transparent. I want to make them toned when rendering
Thu, May 15, 2008 at 2:27:08 PM
Glass keeps rendering black not transparent
Mon, Jan 23, 2006 at 4:01:41 AM
Transparent textile in rendering
Thu, Jan 6, 2011 at 8:43:04 PM
Page generation time: 5.0988
