Forums >> Revit Structure >> Technical Support >> How do you darken hatch lines?
Thu, Jul 23, 2009 at 7:17:15 AM | How do you darken hatch lines?
jmorabito
I know my question doesn't only pertain to Revit Structure but I wasn't sure where else to ask.  My company works in Revit Structure '09 & '10.  In CAD we show our hatch lines  Cryingeg. masonry hatch) as darker lines then what Revit plots out.  Is there any way we can darken the hatch?  Thanks.
Edited on: Thu, Jul 23, 2009 at 7:18:26 AM
Thu, Jul 23, 2009 at 7:40:52 AM | How do you darken hatch lines?
Unless they changed something in 2010, I think all hatches use pen 1 by default.  So far, I've not seen anything written on this for 2010.
Thu, Jul 23, 2009 at 8:50:53 AM | How do you darken hatch lines?
jmorabito
Is pen 1 equivalent to line weight 1?  If so how would I go about increasing that to line weight 3?
Thu, Jul 23, 2009 at 9:41:53 AM | How do you darken hatch lines?
Sorry - yes, what I called pen 1 is lineweight 1.  Sure - you can change it under settings\line weights but beware!  Your lowest lineweight may now have to be lineweight 2 and you will have to change everything that used #1 and that you want to remain at that lineweight.
I see that you are a new member and if you are new to REVIT, I suggest you hold off making changes like this until you fully understand the consequences.  Most of us have learned to live with REVIT rather than trying to make it conform to CAD standards.
Number hatch for ceiling plan
Mon, Dec 17, 2007 at 12:48:09 PM
PHASEING HATCH LINES?
Thu, Jan 11, 2007 at 4:43:26 AM
Can you darken every 5' contour line?
Mon, Aug 15, 2011 at 9:23:34 AM
HATCH 22- REVIT MODEL HATCH
Fri, May 8, 2015 at 3:01:04 AM
Earth Hatch
Tue, Nov 29, 2011 at 5:23:49 PM
Page generation time: 1.4885
