22 Users Online (20 Members):
Forums >> Community >> Newbies >> Rotating View Ports on Sheets
5 Posts No Rating |
I have a horizontal sheet layout and rotated the view port 90 degrees to fit on the sheet. When I rotated the viewport, the viewport title didn't rotate with the view. Is there any way to rotate the viewport title as well? I have attached a jpg to help explain my situation. Any help would be great. Thanks
You can get around that by rotating the viewport before bringing it into the sheet. The title will then still be orientated horizontally.
7 Posts No Rating |
Make the viewport active, pick cropping window, rotate 90 degrees, then adjust window to suit view. View will be rotated without rotating view title.
conditional formatting yes no parameters |
Tue, Oct 28, 2008 at 9:58:54 AM
Rotating views in sheets |
Thu, Nov 8, 2007 at 5:26:50 PM
Rotating Views On a Sheet [ 1 2 ] |
Tue, Jun 17, 2008 at 12:49:46 AM
18
Rotating View Titles |
Sun, Feb 8, 2015 at 2:10:09 PM
Rotating details on sheets without rotating their callouts in plan |
Wed, Dec 10, 2008 at 5:28:37 PM
