Forums >> Revit Building >> Technical Support >> Grid Dimension shown views
Wed, Jul 22, 2009 at 5:31:36 AM | Grid Dimension shown views
line
Hi                                  I have a grid which is currently dimensioned in one plan. Is there a way of applying this dimension to all plans without having to copy them across?
As dimensions are a special element like the levels, I would assume there could be a way to show the dimensions for the grid whitout having to copy them around. But maybe this is one for the wishlist.                                            Thanks
Wed, Jul 22, 2009 at 7:06:39 AM | Grid Dimension shown views
Open the plan with your dimensions and select them all - copy to clipboard ... open your other plans and paste same place.
Read your HERLP - these topics : Copying Elements to the Clipboard
Pasting Elements from the Clipboard
Pasting Aligned Elements
Wed, Jul 22, 2009 at 8:29:13 AM | Grid Dimension shown views
line
Thanks HUB
I always uses the help file before posting an issue but thanks for the reminder.
I had hoped that there was another way than using the copy/paste command, as grid dimensions has to be shown every time the grid is shown. Therefore it made sense if there was a different way than with ordinary dimensioning.
workaround for dimension partially of view so not shown
Tue, Apr 26, 2016 at 10:28:58 AM
Grid Dimensioning
Tue, Jun 3, 2008 at 5:49:38 PM
Dimension or Detail Component?
Mon, Nov 18, 2013 at 3:24:16 PM
Dimensioning tolerances to use align dimension with grid lines ?
Tue, Feb 9, 2016 at 11:18:30 AM
Different Grid Bubble for different scale views?
Thu, Dec 12, 2013 at 5:42:13 AM
Page generation time: 0.8883
