Forums >> Revit Building >> Technical Support >> Door Placement
Tue, Aug 2, 2005 at 10:54:38 PM | Door Placement
Audrie
Hi. I am new to Revit - this week actually, and am trying to do my first drawing. Can anyone tell me why when I place a steel internal door it doesn't place it centrally and clearly the frame is too big for the 90 steel frame wall. Any door I place seems to have the same problem. Why I can't adjust the door to accommodate different wall thicknesses? Grateful for some help Thanks Audrie
Wed, Aug 3, 2005 at 11:02:00 AM | RE: Door Placement
TomDorner
4.5 Stars: 25 Votes
It all depends on what door family you are using as to how it behaves. Most of the standard doors included with Revit cut the entire width of the wall and do not show a frame. If you want a frame included with the door that is not the entire width of the wall, you need to find/modify/develop one that works for you. The family explorer on this site is the first place I would look to find a door that meets your needs. HTH Tom
Door tag placement??
Thu, Jun 8, 2006 at 11:44:11 PM
Curtain Wall Door Placement Location
Tue, Jul 26, 2016 at 7:52:26 AM
Doors, Door jambs, and placement in walls
Fri, Feb 22, 2013 at 9:30:07 AM
Curtain wall door
Wed, May 12, 2010 at 3:38:11 AM
Having annotations show up nested in a door fmaily withtin project
Wed, Feb 29, 2012 at 11:28:07 AM
Page generation time: 1.9195
