Forums >> Revit Building >> Technical Support >> Masking an imported link
Tue, Jul 21, 2009 at 4:00:52 PM | Masking an imported link
joshb
I was wondering if there is anyway to mask over an imported revit link? I have imported in a floor plan that I will be doing plumbing work over top of but I need to mask over part of the column grid that interferes with the key plan once it is brought into a sheet view. I have tried making the link an attachment as well as an overlay but the masked region still won't cover up what I need it to.
 Thanks!
Tue, Jul 21, 2009 at 4:16:35 PM | Masking an imported link
Masking regions mask all model elements including linked files.  You must be doing something else.
Tue, Jul 21, 2009 at 4:20:41 PM | Masking an imported link
joshb
Any suggestions of what I could be doing wrong?
Mon, Dec 7, 2009 at 9:16:42 AM | Masking an imported link
ericdpete
I have also had this problem. I don't think I am doing anything wrong as I have used masking regions quite a bit and they really aren't that complicated to begin with... The mask will cover any elements I have added but the link still shows.
Mon, Dec 7, 2009 at 10:20:15 AM | Masking an imported link
I repeat - model elements.  Are you trying to mask annotative elements in a linked view?
Mon, Dec 7, 2009 at 12:57:41 PM | Masking an imported link
ericdpete
Yes, I am trying to mask annotation.
Mon, Dec 7, 2009 at 1:03:03 PM | Masking an imported link
Annotations will not mask....Not even in your own model.
Mon, Dec 7, 2009 at 6:04:16 PM | Masking an imported link
eldados
eldados Avatar
4.5 Stars: 8 Votes
you can control what is being displayed on your linked model through the Visibility/Graphics settings of your view.
if you choose custom settings you can turn off/on any element.  you can turn off your annotations altogether. like WWhub said, masking regions will not cover annotations, and I'll used them sparsely...
Integrator
KarelCAD
Tue, Dec 8, 2009 at 7:48:34 AM | Masking an imported link
ericdpete
The issue we are having is that only a few of the annotations (room tags in this case) need to be hidden while the others need to show.
Mon, Aug 22, 2011 at 10:56:06 PM | Masking an imported link
mirakation
i think you should hide the stuff you dont need before linking it into Revit. that is the best option i can think of right now.
Smile
Tue, Aug 23, 2011 at 7:06:43 AM | Masking an imported link
mirakation,
No, you don't want to open the linked file and turn them off there.  That defeats the linking process.
You can hide individual elements from a linked file.  You can also turn off categories in a linked file independent of your view using VG.
Tue, Aug 23, 2011 at 8:59:04 PM | WWHub
mirakation
Quoting WWHub from 2011-08-23 07:06:43
WELL I THINK THERE IS MISUNDERSTANDING HERE, I SAID MODIFY THE 2D DRAWING BEFORE LINKING THEM INTO REVIT NOT MODIFY THEM AFTER THEY HAVE BEEN LINKED ALREADY Smile
mirakation,
Wed, Aug 24, 2011 at 7:06:35 AM | Masking an imported link
#13
mirakation,
There is a misunderstanding but it seems to be yours.  The question was about a Revit link, not a 2D drawing link.
The 2D items in question are from a linked revit view and should be controlled by category through VG or individually using the tab key and over-riding graphics in view.
Wed, Aug 24, 2011 at 5:59:56 PM | WWHub
#14
mirakation
sorry my bad Sad
Quoting WWHub from 2011-08-24 07:06:35
mirakation,
Printing issues with masking region
Fri, Aug 29, 2008 at 6:01:02 PM
Revit 2010 Masking Regions
Mon, Nov 30, 2009 at 4:42:34 PM
Masking region in a family inside another family??
Tue, Jun 19, 2012 at 8:28:23 AM
masking regions overlap other views in sheet?
Thu, Jul 7, 2016 at 11:14:07 AM
Masking Regions and Discipline
Wed, Oct 24, 2012 at 1:24:18 PM
Page generation time: 0.2285
