Forums >> Revit Systems >> Technical Support >> Calculating floor areas
Tue, Jul 21, 2009 at 2:17:47 PM | Calculating floor areas
koolair
4.5 Stars: 2 Votes
Does anyone know how to calculate room areas like you do in AutoCAD?  I would like to simply enclose an area with lines and determine the square footage covered by that area.
I realize you probably need to do a room schedule, but I want a quick work around to get a quick answer.
Thanks!
Tue, Jul 21, 2009 at 3:08:01 PM | Calculating floor areas
koolair
4.5 Stars: 2 Votes
ok guys, I'm gonna answer my own question here, in case there are some who say I never contribute =).  This'll be my public service announcement for the advancement of Revit....I hope my time is tax deductable ;D
In order to quickly display an area go to the ROOM AND AREA tab of the design bar.  If you don't see it, R-click and check it off.  It'll fall under the DRAFTING tab.
Hit "Area Plan", and it'll prompt you to create a new floor plan just the way you would when you set up your project in the beginning.  Create your new floor plan.
In your new floor plan, filter out all the junk (ie, go to visibility graphics and turn off all ducts, equipment, pipes, REFERENCE LINES AND PLANES, sections, etc....).  This is just so you have a clean plan to work with.
Now in the ROOM AND AREA tab, hit area boundary, then at the top click the pencil icon (draw).  Draw your boundary around the room you're interested in.
Click on either "Area" or "Area Tag" in the design bar and drop it into the bound region you just drew.
Viola!
Enjoy it everyone!
Now if I could only get my head around scheduling......tale for another day.
Joe
Tue, Jul 21, 2009 at 3:26:06 PM | Calculating floor areas
ThatGuy
you can do an area plan
1 select area plan and the floor you want.
2 select NO for automatic boundary creation
3 then use area boundary lines to enclose the area
4 use the AREA to create the defined space
5 tag it or click on the X that makes up the room area and look at its properties to see the Square Footage or the Perimeter
I hope  this help
Have a Great Day Smile
Tue, Jul 21, 2009 at 3:34:21 PM | Calculating floor areas
You can also just do a drafting fill and its properties will show you an area.
Tue, Jul 21, 2009 at 3:35:52 PM | Calculating floor areas
koolair
4.5 Stars: 2 Votes
Viola!
Enjoy it everyone!
Joe
Tue, Jul 21, 2009 at 3:42:43 PM | Calculating floor areas
ThatGuy
Thanks WWHub i didnt know that
Calculating glazing areas
Tue, May 26, 2009 at 8:42:32 AM
Floor Areas and Shaft Areas
Tue, Jul 29, 2008 at 3:04:18 PM
Custom gross areas
Tue, May 3, 2011 at 7:51:13 AM
rooma area of several room areas
Mon, Apr 19, 2010 at 1:45:30 PM
Calculating Wall Tiles AREAS
Mon, May 31, 2010 at 6:23:08 AM
Page generation time: 2.5930
