Forums >> General Discussion >> Revit ROI >> compatability
Mon, Jul 20, 2009 at 7:27:19 PM | compatability
auserofrevit
okay - i will admit that i did a very quick search to see what had been said but wanted to cut to the chase -
revit will not allow forward or backward compatability
so does this also apply to families as well?
what a colossal waste of resources and time if true.
Mon, Jul 20, 2009 at 10:16:57 PM | compatability
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes this is correct.  For both families and projects you cannot save files back to a previous version.
Backwards compatibility will never be supported in Revit.  If you are using the latest version you don't have an issue.  Which is why Autodesk has a subscription program...
I get so sick of this argument and I'm sure I'm not alone...
Regards,
Chris.
Tue, Jul 21, 2009 at 6:42:19 AM | compatability
Mr. Spot,
You missed that he said foward compatable...Revit IS forward compatable... that is, you can always open an older file and upgrade it.
Tue, Jul 21, 2009 at 8:47:19 AM | compatability
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Dead on Spot and yes WW as long as you have the latest release you can open older REVIT files and families.
People must understand that REVIT is not a 2d vector based program, word processor or spread sheet. It is sophisticated Building Information Modeling across multiple disciplines which involves in-depth analysis and system integration..
In my opinion 'backward' compatibility in the CAD world is a bad bad habit that has been accepted and entrenched from the DWG. It establishes a breading ground that caters to 'software pirates'. Not that I am making any accusations in this thread.
I believe a robust BIM CAD software cannot continue to move ahead and make improvements when the file format stays the same. Autodesk turned a blind eye to DWG pirates for many years in order to gain market share. That is a fact..
And YES, we are definitely in a storm right now because REVIT 2010 for the first time in its existence has rolled out a substandard product and it is causing a substantial slow down in upgrading. I cannot defend that. However I have faith that that it will change.
One of the many strengths and attractions of using REVIT has always been that 'everyone is on the same release' and I hope it stays that way. Autodesk used to force you to be on subscription until they were legally bound to remove that constraint (pun intended). I would have just as sooned let it be..
 I know from personal experience over many years that trying to run an office and paying someone to constantly deal with different file formats back and forth is a $%#^ nightmare. . . . and THAT is a waste of time and money..
It's never pleasant trying to explain to the white haired company principals that you need another day because you have to deal with glitches from a file from 2-3 releases ago that contain old nested blocks and you need to start flipping files around and hope to God there's a lisp routine out there that helps (aka Bonus tools). .
Nope, I'll take a single file format any day of the week and be productive doing so : )
Edited on: Wed, Aug 12, 2009 at 9:30:38 PM
Tue, Jul 21, 2009 at 10:14:16 AM | Mr Spot
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting Mr Spot from 2009-07-20 22:16:57
you can add me to the ditto list
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Jul 21, 2009 at 10:26:53 AM | compatability
I think we just have to give these new users time to understand that this is a strength - not a weakness.  If they never get that, then that's their weakness.
Tue, Jul 21, 2009 at 10:42:21 AM | compatability
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Agreed, hense my detailed reply : )  It's a substancial culture change from traditional CAD. I had a post earlier where I made the statement "We must all band together like '300' (the movie) and fight off the evil forces of multiple file format !
Stupid compatability question
Tue, Mar 29, 2011 at 8:29:14 AM
Revit & 64bit compatability
Mon, Nov 3, 2008 at 9:54:55 PM
13
Revit 9.0 and Inventor 11 compatability
Tue, May 8, 2007 at 9:22:47 AM
2010 to 2009 compatibility
Sat, May 2, 2009 at 12:10:33 PM
working on two templates
Wed, Nov 21, 2012 at 11:23:33 AM
Page generation time: 0.1053
