25 Users Online (23 Members):
Forums >> Revit Systems >> Technical Support >> actually showing low voltage wiring in the model, is it possible?
I know that Revit MEP has allot to be desired in regards to the electrical aspect, but I was wondering if anyone has attempted to actually show in the model actual low voltage wiring. Would it even be possible to show a 1/4" diameter wire/conduit/pipe/etc within the model and show it as low voltage wire from one point to another? A customer of ours is interested in being able to account for these in the model. Can a family be made that could be one continuous piece from one end to the other, going up, around, and down as needed so that when selected, it would show the path of travel and information added to it in regards to what it connect to and from where? Any thoughts or ideas would be appreciated.
If you have found out already, best way to do this is to use piping, I have created conduit fittings for a specific pipe type.
http://familyjewels.typepad.com/ |
Is there a way to make a flexible pipe that can be flexed withn the model? The problem with piping is that each bend is a fitting. I can make 1/4" diameter pipes and fittings, but if I want to make a lengthy run of pipe (wire) as a solid selectable object, with data attached to it, can it be done?
Low voltage wiring in Revit MEP |
Fri, Apr 23, 2010 at 4:34:26 PM
Revit for Low Voltage Structured Cabling |
Tue, Jan 13, 2009 at 8:17:17 PM
Electrical wiring |
Wed, Nov 12, 2008 at 4:22:36 AM
error: Voltage for the Circuit is out of range for the Line to Ground Voltage... |
Sun, Sep 30, 2012 at 12:16:31 PM
Mid-project Program Update (Revit 2011 to 2012) HELP PLEASE! |
Wed, Dec 7, 2011 at 8:54:53 AM
