25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> export cad text file BS1192
24 Posts No Rating |
Revit 2009 Hi, Can some one upload the BS1192 standards revit cad export setting text file? I think I have edited the standard BS1192 text file. Tought it would be a read only file but it does not seem like that. If someone could upload their txt file to here it would be fantastic. You can find the export file here; C:\Program Files\Revit Architecture 2009\Data Thanks
Unaltered version attached.
thanks Tim, I have inserted it back into my file. I still have problems with the cad print as it does not show up properly, almost though. I assume that the bs1192 standard is referring back to the little pcp file which appears when exporting from Revit. So in cad I have made the pcp file into a ctb plotstyle. I then assumed that the print in cad would be very similar to the print in revit, but some of the colours of the layers are there. I am also wondering why Revit's cad file would not export to read stb plotstyles and instead reads ctb plotstyle as revit is object based program.  so named based plotstyle instead of layer based).
Export the Point cloud file to Auto CAD with Revit |
Wed, Apr 2, 2014 at 4:38:32 PM
Revit Export to CAD |
Mon, Jul 21, 2014 at 8:35:51 AM
Revit to CAD text issue |
Sat, Feb 25, 2012 at 7:40:09 AM
EXPORT CAD |
Fri, Jun 15, 2007 at 10:37:19 AM
Export from Revit To CAD with RELATIVE linked files |
Wed, Nov 29, 2017 at 11:00:35 AM
