Forums >> Revit Systems >> Technical Support >> Callouts (copy-paste aligned)
Mon, Jul 20, 2009 at 9:51:26 AM | Callouts (copy-paste aligned)
koolair
4.5 Stars: 2 Votes
I have floor plans that I need to break up into separate areas, so I'm using callouts.
Three of my floors will have the same area configuration, so I created callouts on one of them, copied, and pasted (aligned)-->Current View (while in the floor above).  The paste worked, but the warning bubble popped up and said, "Elements have been deleted".
None of the copied callouts are on the floor plan above.  I would like to PASTE ALIGNED-->SELECT LEVELS BY NAME, but the floor plan I want to paste to doesn't show up on the list.
Any ideas?
Thanks
Paste Aligned in Current View Keyboard Shortcut
Wed, Dec 17, 2008 at 6:14:41 PM
Objects on floor above showing
Tue, Apr 28, 2015 at 1:09:42 PM
Revit MEP 2010 copy/paste lighting fixtures
Sun, Feb 16, 2014 at 12:46:34 AM
CALLOUTS
Thu, Oct 19, 2006 at 3:13:10 AM
Copy and Paste
Fri, Mar 6, 2009 at 5:31:33 PM
Page generation time: 4.3168
