16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> how to add keyboard shortcut for mirror draw in 2010
is this possible?
Macca Sunshine Coast QLD Australia |
I don't think it is possible at the moment. MM is the default using the mirror by axis function. Hopefully this will be fixed soon.
14 Posts No Rating |
Here's what I'm using. "MP" ribbon:"ContextualTab-Modify-Mirror-Pick Mirror Axis" "MI" ribbon:"ContextualTab-Modify-Mirror-Draw Mirror Axis" It's pretty simple to shortcut most commands in the ribbon. Just follow the format for each ribbon and make sure you replace ALL instances found in the file.
Edited on: Mon, Jul 20, 2009 at 1:39:28 PM
I stand corrected. I didn't realise that you could add commands to the shortcut file, but this does indeed work. Thanks for that.
Keyboard Shortcuts |
Thu, Jan 20, 2005 at 5:15:30 PM
Isolate Elements keyboard shortcut |
Tue, Dec 15, 2009 at 4:41:48 PM
Looking for quick Key shortcut |
Thu, Jul 2, 2009 at 10:22:19 AM
Some Keyboard shortcuts not working? |
Tue, May 5, 2009 at 2:52:55 PM
Exported Keyboard Shortcut file is .xml format - can't open in Excel |
Fri, Jan 13, 2012 at 11:41:37 AM
