Forums >> Revit Building >> Technical Support >> Dimension Lumber
Sun, Jul 19, 2009 at 1:04:53 PM | Dimension Lumber
learningtofly
I am loading the group in Revit and I cant seem to figure out how to actually use it. I do not see it listed as a compent. I am sure I am missing something very simple but I am just getting frusterated cause I need to do some trim detailing and need to use the lumber.
Thanks for you help!
Sun, Jul 19, 2009 at 1:25:56 PM | Dimension Lumber
You loaded a group?
I think you loaded a detail element.  Most detail elements are complete as is but some have parametric qualities.  You add these to drafting or model views.  In model views, you will also use the edit cut profile to edit the cut profile of model elements.  You may also add linework, filled or masking regions and you might modefify model lines by using the linework tool.
How can I get a lumber section symbol?
Tue, Aug 4, 2009 at 12:55:06 PM
Problem adjusting dimensional lumber length
Wed, Aug 14, 2013 at 5:13:20 PM
Loading families like dimensional lumber
Wed, Aug 2, 2006 at 7:26:20 AM
dimension lumber
Mon, Aug 13, 2007 at 2:30:51 AM
Dimensional Lumber in Elevation + Plan
Fri, Oct 18, 2013 at 2:39:14 PM
Page generation time: 2.2246
