Forums >> Revit Building >> Technical Support >> Plotting
Tue, Aug 2, 2005 at 4:37:55 PM | Plotting
lpromana
4 Stars: 2 Votes
How can I avoid the "rounded" line intersections when plotting, can I get defined corners?
Tue, Aug 2, 2005 at 5:38:43 PM | RE: Plotting
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Unfortunately Revit doesn't have this setting. To do this the workaround is to use a filled region as opposed to a thick line. That way you can define the edges with a thing line and just have a solid fill to make up the gap in between.
Fri, Jun 19, 2009 at 1:57:15 PM | Plotting
ConorOB
ConorOB Avatar
thats ludicrous- youre saying that Revit wont plot sharp, hard full 90 degree corners??
HDK
Fri, Jun 19, 2009 at 2:08:28 PM | Plotting
It sure does plot shap corners ... for thin lines.  Think of this like the old leroy pens....
Fri, Jun 19, 2009 at 2:08:41 PM | Plotting
lpromana
4 Stars: 2 Votes
let me reply to my own question of 3 years ago and clarify this, Revit will plot sharp corners, what happens is that if you are in a for example 1/4 " scale in your view and you zoom in real close into any corner made by two lines, because of the zoom that corner will appear "rounded" but keep in mind that you are zooming in into the view not changing the scale when you plot the corners are sharp
Fri, Jun 19, 2009 at 2:12:10 PM | Plotting
ConorOB
ConorOB Avatar
okay, so:
1) Revit plotting is as sharp, hard and clear as AutoCAD?
2) Within Revit, ie while working, the lines displayed on the screen maybe rounded but they will NOT print out as such?
 Plotting is a pretty big deal, so glad for the prompt feedback! Smile
HDK
Fri, Jun 19, 2009 at 4:31:47 PM | Plotting
jarosa
jarosa Avatar
4 Stars: 5 Votes
To summarize what was already stated, Revit's lines have rounded ends and corners. This is only a problem with very thick lines at very large scales. Revit programmers chose this type of corner/end in the early development stages of the program. In general drafting this should not be a problem. But Revit is a WYSIWYG program so it definitley prints what's on the screen, but at 1/4" scale you can't tell that a thin line has rounded corners/ends.
If you have to have square ends and corners the work around is to use a filled region with thin lines and solid fill.
HTH,
John
plotting to a plotting service plotter with a prn file
Wed, Jun 4, 2008 at 1:14:56 PM
Plotting PDF's
Tue, Jul 21, 2009 at 4:18:05 PM
Plotting HELP!!
Tue, Nov 14, 2006 at 3:13:10 PM
Plotting
Fri, Apr 28, 2006 at 8:31:02 PM
plotting problem
Wed, Dec 22, 2004 at 3:44:51 PM
Page generation time: 0.0370
