Forums >> Community >> Newbies >> Gutter Sweep
Fri, Jul 17, 2009 at 9:34:22 AM | Gutter Sweep
TripleU
Hi All,
Having a little difficulty with the attached file from a manufacturer. Firstly, I need to convert it from metric to imperial. Second, the half round gutter is way out of scale even for metric.
I understand how to change units via Settings --> Project Units. However, when I manually scale the gutter down by "0.038449" to get the exact size I need, Revit tells me that it "contains no loops" when I try to load it.
 Thanks.
Revit Arch 2009
Fri, Jul 17, 2009 at 9:47:52 AM | Gutter Sweep
4 Stars: 205 Votes
If you "Scale" that to "0.038449" you have a Gutter with less than 2 inches, that gutter must have "0.38449" and not "0.038449", i edit that gutter, scale then load into project, no problem, but the scale you are doing, that's the problem...
Fri, Jul 17, 2009 at 10:33:42 AM | Gutter Sweep
TripleU
Hi Typhoon,
At a scale of 0.38449 the model is importing at around 3 feet high. The original gutter is 100mm at the highest point, but when I change the unit settings it looks as if it is translating into 100 inches or 8' 2 1/2" (rather than 3.8449 inches).
My thinking was to accept the 100 inches height, and then scale down by 0.038449 to get the 3.8449" desired, but that's where I start to get the "contains no loops" error once imported.
Thanks.
Revit Arch 2009
Fri, Jul 17, 2009 at 10:41:09 AM | Gutter Sweep
4 Stars: 205 Votes
Because 0.038... it's to Small, the offset of the lines are "0.0003m", Revit don't assume that value, the minimun is "0.002m", that's why it gives the error...
Fri, Jul 17, 2009 at 11:21:50 AM | Gutter Sweep
TripleU
Solved! Scaled down the gutter, and all I had to do was thicken the gutter material. It's strange that the manufacturer didn't have the material scaled to the size properly. Only trouble now is the setting the reference planes because it is hanging in mid air once inserted.
Revit Arch 2009
Anyone got an easy way to cap the end of a gutter sweep? Anyone?
Wed, Feb 14, 2007 at 7:22:46 PM
Huge Gutter Issues
Wed, Oct 3, 2007 at 7:44:12 AM
HOST SWEEPS?
Tue, Aug 29, 2006 at 11:25:22 PM
Gutter with no mitre joints
Fri, Apr 24, 2009 at 5:06:20 PM
Gutter display on roof plan
Mon, Jun 11, 2007 at 3:47:21 PM
Page generation time: 1.4972
