Forums >> Revit Building >> Tips & Tricks >> Turning off views on a sheet
Wed, Jul 15, 2009 at 2:33:42 PM | Turning off views on a sheet
MARS1276
1 Stars: 1 Votes
Is there a way to do this?  A work-around perhaps?
I would like to be able to turn off (or have the option not to print) some of the views I place on a sheet drawing.  I have a page with Wall Sections and later I added some Stair Details.  If I want to print the page without showing the Stair Details is there a way I can do this?  I don't want to have to delete the view just to place it again back on the sheet at a later date.
Fri, Jul 17, 2009 at 8:43:04 AM | Turning off views on a sheet
rkitect
rkitect Avatar
4 Stars: 29 Votes
Have you tried just hiding the view?  Select the view, and either type "HH", then "Apply Hide/Isolate to view" using the sunglasses at the bottom of the view, or you can right click the view and select "Hide in View > Elements."
HTH,
Carl
turning on/off nested families in host family in different views in project.
Fri, Aug 7, 2009 at 11:11:32 AM
Turning off views on a sheet?
Wed, Jul 15, 2009 at 2:36:43 PM
turning off levels below current on your sheet view
Thu, Jun 10, 2010 at 12:19:11 PM
Turning off one object in all views with one step?
Thu, Mar 27, 2008 at 4:58:50 PM
Sheet Underlay
Fri, Sep 12, 2014 at 2:13:25 PM
Page generation time: 1.0998
