Forums >> Workflow & Implementation >> API & Third Party Apps >> ActiveDocument.Elements vs. ActiveDocument.ActiveView.Elements
Wed, Jul 15, 2009 at 1:42:16 PM | ActiveDocument.Elements vs. ActiveDocument.ActiveView.Elements
rkitect
rkitect Avatar
4 Stars: 29 Votes
I'm trying to get an element set from the active view using a some code from th DevTV tutorials.  This works to grab an element set from the entire model:
ElementSet elems = revitApp.Create.NewElementSet();            ElementIterator iter = revitApp.ActiveDocument.Elements;            while (iter.MoveNext())
So I assumed that changing it to
ElementSet elems = revitApp.Create.NewElementSet();            ElementIterator iter = revitApp.ActiveDocument.ActiveView.Elements;            while (iter.MoveNext())
Would allow me to work from the active view element set however, I'm getting the error:
"Cannot implicitly convert type 'Autodesk.Revit.ElementSet' to 'Autodesk.Revit.ElementIterator'"
Any insight into why this happens and what the type difference between the Elements object in ActiveDocument is compared to ActiveView?
TIA,
Replacing Structural Elements in Arch Model with Revit Structure elements
Sun, Dec 4, 2011 at 4:06:34 AM
Cleaning Up Design Option Elements with Main Model Elements
Wed, Jun 17, 2015 at 1:38:27 PM
Receiving "Can't keep elements joined" message when joining 3 family elements
Tue, Apr 21, 2015 at 11:26:44 AM
Newbie - Need help with mass elements
Mon, Feb 8, 2010 at 1:11:14 PM
How to work with the elements from link
Tue, May 27, 2008 at 12:14:43 PM
Page generation time: 0.1490
