Forums >> Revit Building >> Technical Support >> Pull down menus not showing up
Tue, Aug 2, 2005 at 11:11:06 AM | Pull down menus not showing up
SRobbins
Anyone have the problem of pull down menus not showing up for the properties of a object or family? I need a solution for this other then "just start typing in what you want and it will show up" We have users just starting this and they dont know the naming conventions so they wouldn't know what to start typing. I need a real solution from Autodesk or someone.
Tue, Aug 2, 2005 at 11:26:11 AM | RE: Pull down menus not showing up
SRobbins
Got it... Make the monitor that Revit is on, in a duel monitor setup, the primary monitor to see them again.
Title block pull down menus
Thu, Feb 16, 2017 at 7:44:15 PM
Pull Downs get "tired"
Tue, Dec 6, 2005 at 8:14:42 PM
11
Not all Components showing in pull down menu
Tue, Dec 29, 2020 at 6:51:50 AM
some pop-up menus do not appear
Wed, Jun 7, 2017 at 5:37:40 AM
I wish I may, I wish Autodesk might...
Sat, Apr 17, 2010 at 2:17:35 PM
Page generation time: 0.7279
