25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Creating a wall finishes schedule, and coding wall finishes on elevations
1 Posts No Rating |
Our team has run into what seems to be a weakness in Revit. We have several specialty finishes on walls in our project. These finishes are identified in the Wall Types, ie a wall which has tile on it has the tile shown in the wall type structure in the Element Properties dialogue box. We are able to label ceiling and floor finish specs with no problem. Since this is a wall type, when we label elevations with tile (for example) the label shows the wall type, but not the finish spec. What I need is a way to show the spec for the wall finishes: The finish, color, manufacturer, et. of the finish. We have seven different paint colors distributed throughout the project, as well as 5 types of wall tile, fabric panels, and wood wallcovering. I hope this is understandable, and any suggestions would be appreciated. Thanks Dina
Be creative. Wall tags can be set to read various fields that are already in your walls as well as other shared parameters.
15 Posts No Rating |
dinacheyette
I am sort of having similar problem. If you find out any solutions, please let me know.
Thank you!
wall finishes by room |
Tue, Apr 19, 2005 at 11:40:25 AM
Wall finishes and grade |
Tue, Aug 31, 2010 at 12:33:10 AM
Internal Wall Finishes |
Tue, Mar 25, 2014 at 4:18:18 PM
Wall interior finishes - new wall type or a better way? |
Tue, Mar 8, 2005 at 1:07:59 PM
Creating different Masonry walls with different finishes |
Sat, Feb 4, 2012 at 9:07:02 PM
