Forums >> Revit Systems >> Technical Support >> Lineweight issue
Wed, Jul 15, 2009 at 10:40:46 AM | Lineweight issue
Moore44
I can't control the lineweights in a detail view because they are specified by the detail components (the c channels) and the walls so the issue is that the c channel's lighter lineweight is overriding the wall. Is there a fix for this issue?
Wed, Jul 15, 2009 at 10:50:40 AM | Lineweight issue
Detail lineweigts are controlled through Settings/Object Styles/ Model Objects tab / Detail Items
Wed, Jul 15, 2009 at 11:01:15 AM | Lineweight issue
Moore44
Thank you for the assist. I truly appreciate it. I'm new to the Revit game.
Structural Footing Lineweight Issue
Mon, Jun 18, 2018 at 12:05:57 PM
export to cad lineweight issue.
Wed, May 27, 2009 at 9:51:17 AM
How to reduce lineweight for filled region
Thu, May 29, 2008 at 4:57:50 AM
Lineweight on Surface Patterns?
Mon, Jun 15, 2009 at 11:54:52 AM
OBJECT STYLE ISSUE
Fri, Jan 30, 2015 at 10:34:36 AM
Page generation time: 0.2196
