24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Detail Line problem
26 Posts No Rating |
i'm trying to draw a circle on a floor plan to show handicap clear floor area. i would think i want a detail line, not a model line. (i understand the difference)...but it gives me a message that it is "not visible in the current view"...i've encountered this before, but for some reason, i cant remember how to correct this. any help would be appreciated, thanks.
Do you have the lines on in VG?
i think i figured it out. the detail lines are drawn on the work plane...which is the floor. However, i have a floor finish (VCT) on top of the floor that is covering the detail line. I guess i need to make the level height to be the top of the VCT? (that stinks)
nope. that wasnt it either. i'm clueless. (yes, it is "on" in VG)
You said you knew the difference between detail and model lines. Detail lines are strictly 2D. They are on top of everything. You are using model lines!
i got it. i WAS using detail lines, however, the line type was i was using was an imported and frozen line of the same name as the line type i wanted. stupid me. but thanks for the help. carry on.
Detail Lines Follow Model Line Weights Problem |
Fri, Sep 9, 2011 at 9:55:51 AM
Line thickness in detail family |
Wed, Jul 1, 2015 at 7:09:56 AM
Detail Line won't change from Revision Cloud type |
Sat, Dec 3, 2011 at 1:14:20 AM
locking detail line to ceiling for elevation view. |
Fri, Jan 23, 2009 at 4:00:42 PM
Detail Component line weights |
Wed, Jan 7, 2009 at 4:44:09 PM
